[Qgis-user] QGIS for Windows with GSS/Kerberos/Active Directory
chris hermansen clhermansen at gmail.com
Fri Feb 3 09:02:30 PST 2023
Tomas and list,
On Fri, Feb 3, 2023 at 8:11 AM Tomas Pospisek via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> When I try to set up a connection to a Postgres/Postgis DB server with
> Active Directory/Kerberos/GSS authentication the QGIS DB setup dialog
> displays this message:
>      gssencmode value "require" invalid when GSSAPI support is not
> compiled in
> When I check the Postgres source code [1] I see that apparently this
> gets displayed when GSS support is not compiled in.
> So it seems QGIS as shipped by qgis.org does not ship with GSS support?
> Is that correct?
> Does anybody use QGIS on Windows with GSS? How did you do it?
> I could go ahead and download the EDB Postgres ZIP [3] and exctract
> libpq.dll from it and replace the libqq.dll shipped by the QGIS
> installer with it, but I'm not sure if that would work at all, if that
> would be robust and it'll certainly be a pain to maintain.
> Any pointers/suggestions/help?
Maybe this is the proverbial dumb question... but why not install your EDB
PostgreSQL on your windows machine and run it on a different port?  And
then connect to it from your QGIS instance, on that different port of
course?
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230203/9a21770c/attachment.htm>
More information about the QGIS-User mailing list
