[Qgis-user] Technical advice
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue Feb 7 00:29:14 PST 2023
Hi Assil,
are you 1000% sure the connection details are correct? Does it work with
the same credentials if you use a different tool like DBeaver or
PGAdmin? Do you maybe have some "antivirus" software that makes your
computer not work as intended but blocks some connections?
Cheers, Hannes
Am 07.02.23 um 02:40 schrieb Assil Hafdi via QGIS-User:
> Good evening
> I have encountered an issue with qgis 3.10 where i can't make postgis
> connections despite having postgresql installed and creating my data
> base after i name the connection and set authentication i keep getting
> the ente credentials pop-up even tho i enter the right credentials it
> keeps popping up agter 5 or 6 times it just says connection failed
> would love to get some help since I've scoured the internet for help
> but didn't find anything
> I would appreciate the help since im using qgis for school project
> Thank you in advance
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
15.-18. März 2023 in Berlin
https://fossgis-konferenz.de/2023/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the QGIS-User mailing list
