[Qgis-user] Export to ESRI File Geodatabase
Randal Hale
rjhale at northrivergeographic.com
Tue Jan 17 12:56:50 PST 2023
I don't think this is just me - BUT - I wanted to check before filing a
bug report. This is all with QGIS 3.28.2 On Windows 10 and using GDAL 3.6.1
I was checking on a problem and had used Network Installer to install
QGIS - I had File Geodatabase as a choice for Export (Right Click on
Layer -> Export As ->pick ESRI File Geodatabase).
I installed QGIS using the Stand Alone installer (after removing QGIS
Network Install) and didn't have ESRI File Geodatabase as a choice on
export Features. This is confirmed by another user using the standalone
installer.
I removed QGIS and Reinstalled using the Network Installer and didn't
have ESRI File Geodatabase as a choice (but I did before).
So it seems like I'm missing something - I've been digging through
options and creating new profiles but I can't make the ERI File
Geodatabase consistently appear or disappear. Is there something else I
should try?
Randy
https://www.northrivergeographic.com
(423) 653-3611
More information about the QGIS-User
