[Qgis-user] Dot Density Symbology
chris hermansen clhermansen at gmail.com
Wed Jul 26 11:45:51 PDT 2023
Hugh and list,
On Wed, Jul 26, 2023, 10:24 Hugh Kelley via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi all,
> I've been producing dot density maps for demographics work by using
> postgis to assign points randomly within a polygon with the number of
> points determined by, for example, the total number of a population
> sub-group residing in that polygon.
> I"m wondering if there might be a way to do this directly from the
> polygons in QGIS with symbology.
> I've looked through the resource sharing plugin without luck. I dont'
> think the geometry generator can handle such a task but maybe there's a
> way?
> Here's (apologies for the closed source link) an example of the type of
> map/symbology I'm trying to describe.
> https://www.arcgis.com/apps/mapviewer/index.html?webmap=30d2e10d4d694b3eb4dc4d2e58dbb5a5
> Thanks for any suggestions!
What about just shading the polygons using a gray scale?
Given that your polygons should generate a uniform density of dots within
the area they bound, I don't see value in generating the dots for symbology.
Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230726/c9818757/attachment.htm>
More information about the QGIS-User mailing list
