[Qgis-user] Dot Density Symbology
Shinoto, PD Dr. Maria maria.shinoto at zaw.uni-heidelberg.de
Wed Jul 26 16:59:22 PDT 2023
I have a similar research problem, and the dots seem to be a wonderful solution.
So, this email does not give any assistance re the original question, just an answer to the question below:
Am 2023/07/27 um 03:45 schrieb chris hermansen via QGIS-User <qgis-user at lists.osgeo.org>:
Here's (apologies for the closed source link) an example of the type of map/symbology I'm trying to describe.https://www.arcgis.com/apps/mapviewer/index.html?webmap=30d2e10d4d694b3eb4dc4d2e58dbb5a5
Thanks for any suggestions!
What about just shading the polygons using a gray scale?
Given that your polygons should generate a uniform density of dots within the area they bound, I don't see value in generating the dots for symbology.
The polygon area may vary, as it does in my research (distribution of burials in administrative areas). Therefore, a small area always looks underrepresented as compared to a larger area, and vice versa. I have large administrative areas with low densitiy, but they look well populated even with a very light shade of grey.
So I would like to try to find a solution to Chris' problem since the representation with dots is closer to reality than colouring areas. I will report when I found a solution for my use case -- though this may be autumn...
Maria
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230726/76a2ee31/attachment.htm>
More information about the QGIS-User mailing list
