[Qgis-user] [QGIS-Developer] Proposal? Set 'Use Proxy for Web Access' default ON to 'DefaultProxy'
Richard Duivenvoorde rdmailings at duif.net
Sun Jun 18 23:12:38 PDT 2023
Hi, created a PR for this:
https://github.com/qgis/QGIS/pull/53424
Nobody have this issue/urge?
@Juergen: as you are our 'Windows'-man ;-)  do you see an issue with
this (defaulting to 'Use Default Proxy'?)
Regards,
On 2023-05-17 09:47, Richard Duivenvoorde via QGIS-Developer wrote:
> Hi All,
> Currently a fresh install/profile has 'Use Proxy for Web Access'
> UNchecked.
> I propose to set it CHECKED and then 'Proxy type' to DefaultProxy (all
> see Network Settings)
> This means that if you are in an environment without proxy, it will
> not be in your system environment, so will not be used.
> While if the admins setup the proper proxy, it will also 'just work'.
> Anybody aware of a reason to NOT do this?
> Background: working at institutions/companies which often have some
> kind of proxy enabled, I often have the hassle of making the users
> aware on how to set the web proxy... (because they often want WMS/WFS
> layers from outside the local network)...
> If we would set it by default to "use system proxy" (for what I know
> that is also how most browsers are working), that would solve a lot of
> 'web issues', while (for what I know) would not affect normal use
> without proxies?
> Anybody would have or see an issue with that?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-User mailing list
