[Qgis-user] [EXTERNAL] Re: Geopackage slow on NAS if not read-only
Patrick Dunford enzedrailmaps at gmail.com
Sat Mar 18 12:53:41 PDT 2023
Thanks for this.
You've helped convince me I need to keep a big cabinet with a row of
"huge" tower chassises in it to store all my map data instead of forking
out to get one of those wee little NASs and save a bit of space :)
using Linux on my computer and NFS for networking when I need to open
files on a different computer because the usual one is having some sort
of problem.
lol
On 17/03/23 03:39, jhubbslist--- via QGIS-User wrote:
> You'd only be "living with it" because you choose to use the wrong
> tools for the work and refuse to use the right ones. In this case, I
> see the "wrong tools" here as 1) network-shared files for common r/w
> access 2) the SMB/CIFS protocol in general 3) appliance-type file
> servers are trash. You can try to make things better by standing up a
> proper Linux-based file server and using NFS instead of SMB/CIFS but
> 1) is enough of a problem that you'd only be throwing good work after
> bad.
> If it suits your use cases, you might try implementing something like
> git - which is after a fashion just another networked file-sharing
> protocol - and use check-out/check-in controls to make changes to
> centrally-stored files but this means you'll be slinging entire copies
> of your datasets down to client machines on the regular; that may not
> work well for you.
> The best answer is PostgreSQL/PostGIS and that's going to take some
> time and effort. Cost of doing business.
More information about the QGIS-User mailing list
