[Qgis-user] Placing random points
Thomas Sebastien sebasapp at hotmail.com
Sat Mar 25 02:05:43 PDT 2023
Hi Chris,
Thanks for your help. I used all your suggestions and a combination of them and what works best for me seems to be the layer bounds approach even though my polygons are very irregular in shape. Luckily number of points I need to create is not so big, so I can check that they all fall inside polygons.
Have a good day,
Sébastien
> Le 25 mars 2023 à 04:16, chris hermansen via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
> Andrea and list,
> On Fri, Mar 24, 2023 at 5:00 PM Andrea Giudiceandrea via QGIS-User <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
>> > Thomas Sebastien sebasapp at hotmail.com <http://hotmail.com/>
>> > Fri Mar 24 03:32:25 PDT 2023
>> > what works best for what I’m trying to achieve is dissolving the polygons and placing random points in layer bounds
>> Hi Sebastien,
>> AFAIK, you don't need to dissolve the polygons before using them as
>> input of the "Random points in layer bounds" algorithm: such algorithm
>> correctly places the total chosen number n of random points even if the
>> input N features/polygons are not dissolved.
> I believe I was the one who suggested the layer bounds approach.
> Thomas Sebastian, you do not need to dissolve the polygons if you are only interested in placing the random points within the layer bounds as Andrea says.  If you have a non-rectangular dataset then your layer bounds could result in points being placed outside the polygons in your dataset; you should do the dissolve and place the points within the dissolved polygon.  If like me you live in a rectangular / map-sheet-ish world then by all means work in the layer bounds.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230325/90389487/attachment.htm>
More information about the QGIS-User mailing list
