[Qgis-user] FW: Pansharpening Problem
Richard McDonnell richard.mcdonnell at opw.ie
Thu Nov 16 07:11:01 PST 2023
Apologies,
I forgot to include the list in my response Grant, please see below.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poibl?
Office of Public Works
Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
Sent: 16 November 2023 10:19
To: Grant Boxer <boxerg at iinet.net.au>
Subject: RE: [Qgis-user] Pansharpening Problem
Hi Grant,
The NoDATA values, if not specified are calculated from the source rasters. For RGB imagery, this typically is either 0 or 255, unless you are using an alpha band.
You can though remove the NoDATA tag from the raster. I know of two of ways to do this.
1.       Use gdal_edit with the -unsetnodata, which will modify the existing dataset.
2.       Use gdal_translate to copy the raster but by using the -a_nodata and setting it to none, to remove the NoDATA tag
I would suggest if using the first one, that you make a backup of the raster, just in case.
I hope that helps!
Kind Regards,
Richard
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Grant Boxer via QGIS-User
Sent: 16 November 2023 01:52
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Pansharpening Problem
I am attempting to pansharpen a PRISMA hyperspectral RGB image and I am getting areas within the image that are clipped (no data). These appear to bands with zero values in two of the three bands. Anyone have a work around or suggest how this can be avoided. I am using the gdal pansharpen tool and latest release QGIS 3.34.
Cheers Grant
Perth WA
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231116/8a5ed43b/attachment-0001.htm>
More information about the QGIS-User mailing list
