[Qgis-user] Merge Selected Features crash
Richard Greenwood richard.greenwood at gmail.com
Wed Oct 4 09:39:12 PDT 2023
I believe this is a bug but I'm posting here first in case I'm overlooking
something obvious. Merge Selected Features is causing QGIS 3.32.3 to crash
(close without showing errors). However the same operation on the same data
in 3.28.11 doesn't crash. I copy features from a linestring or polygon
layer and paste them into a temporary memory layer. When I select the
features and use the Merge Selected Features tool on the temporary layer
QGIS closes. It appears to be related to attributes because if I remove all
of the fields from the temporary layer I can merge the features without a
crash. So far the source layers that I've used are postgis. I've tested
with a "clean" profile.
I'm running QGIS 3.32.3 and 3.28 on two different computers, both running
Linux Mint 21.2.
Is there any postmortem info that would help to understand the problem and
hopefully fix it?
Thanks for reading.
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231004/f9fcb4df/attachment.htm>
More information about the QGIS-User mailing list
