[Qgis-user] Flatgeobuf in google drive ?
mhc-qgis at haelsig.net mhc-qgis at haelsig.net
Fri Oct 6 01:20:30 PDT 2023
Another alternative is to use a script at startup of QGIS, which downlaods the
file with wget to a local drive.
<https://medium.com/@acpanjan/download-google-drive-files-using-wget-3c2c025a8b99> .
Kind regards
Michael
Am Freitag, 6. Oktober 2023, 08:26:14 CEST schrieb Adam Nielsen via QGIS-User:
> > However, I would like to use Google Drive as a data repository instead
> > of the website,  so I uploaded the same file to (my) Google Drive in the
> > "Shared Data" directory and made it public viewable using a https
> > address similar to this:
> > *https://drive.google.com/file/d/180sZv.... a lot of letters and
> > numbers....Ue/view?usp=sharing*
> > The question: Is there any method so QGIS can access to the .fgb file
> > located in Google Drive using the information in the above https address ?
> I'm no expert on Google Drive but it looks like you're using the URL
> for the friendly "view this file" page, rather than the URL that
> contains the raw file content itself.
> You'll probably have to try to download the file and grab the download
> URL it gives you there and use that instead.
> Cheers,
> Adam.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
