[Qgis-user] Flatgeobuf in google drive ?
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri Oct 6 03:23:00 PDT 2023
Thanks for all the answers.
I made a Google cloud bucket and uploaded my files to that. It is
(surprisingly🙂) stable and fast ! The only downside is that it takes a
long time the first time you open the layer, because QGIS will read the
entire layer to ascertain the number of objects. When you have a layer
with ca. 6.000.000 objects it takes a looong time. But opening the
project after that is snappy.
Med venlig hilsen / Best regards
Bo Victor Thomsen
On 06-10-2023 09:33, Ujaval Gandhi via QGIS-User wrote:
> Google Drive doesn't allow static file hosting (it used to, but
> stopped around 2015). So you cannot use it to get a file URL that can
> be directly used to get the file contents. You'll need to host the
> file on a static file server or a cloud bucket (Google Cloud Storage
> or AWS s3)
> Ujaval Gandhi
> Spatial Thoughts
> www.spatialthoughts.com
> <https://mailtrack.io/trace/link/8aae70f5bd6ada7857cc248f40e8d91737f68592?w=cWdpcy11c2VyQGxpc3RzLm9zZ2VvLm9yZw&url=http%3A%2F%2Fwww.spatialthoughts.com&userId=8747767&signature=1b1622ce093fbb24>
> On Fri, Oct 6, 2023 at 11:56 AM Adam Nielsen via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>     > However, I would like to use Google Drive as a data repository
>     instead
>     > of the website,  so I uploaded the same file to (my) Google
>     Drive in the
>     > "Shared Data" directory and made it public viewable using a https
>     > address similar to this:
>     > *https://drive.google.com/file/d/180sZv..
>     <https://drive.google.com/file/d/180sZv..>.. a lot of letters and
>     > numbers....Ue/view?usp=sharing*
>     > The question: Is there any method so QGIS can access to the .fgb
>     file
>     > located in Google Drive using the information in the above https
>     address ?
>     I'm no expert on Google Drive but it looks like you're using the URL
>     for the friendly "view this file" page, rather than the URL that
>     contains the raw file content itself.
>     You'll probably have to try to download the file and grab the download
>     URL it gives you there and use that instead.
>     Cheers,
>     Adam.
>     _______________________________________________
>     QGIS-User mailing list
>     QGIS-User at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231006/56f37fac/attachment.htm>
More information about the QGIS-User mailing list
