[Qgis-user] FW: Problem with Georeferences on AutoCAD version
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Sep 1 06:39:36 PDT 2023
Hi Javier,
DWG files are proprietary and can have changes between versions. For this reason, AutoCAD allows users to save there drawings to various versions including.. 2018, 2013, 2010, 2007, 2004, 2000 and R14...
I've found when sending CAD data to 3rd parties that saving to an older DWG format is easier for 3rd party software to use. Usually when sending DWG I would use "AutoCAD 2000/LT2000 Drawing (*.dwg)" as my preferred output format and the same for DXF (AutoCAD 2000/LT2000 DXF (*.dxf))
Easiest solution is to go back to source of the CAD files and have them resave out to a pre-2018 version for you. Alternately there are a number of Free CAD software out there that can take in DWG, which should allow you to save it to an older version......though with post 2018 versions, they may have the same issues..
I hope this clarifies things a little.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Javier Jimenez via QGIS-User
Sent: 01 September 2023 13:36
To: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>; qgis-community-team at lists.osgeo.org<mailto:qgis-community-team at lists.osgeo.org>; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Problem with Georeferences on AutoCAD version
Good morning,
Using QGIS in version 3.28.9 and version 3.32.1 I have had the following problem.
When importing a .dwg file generated by AutoCAD, the application is not able to import the file in versions later than 2018.
How could I import a file from a more current version?
Knowing that most AutoCAD users use current versions with the latest tools, I think it would be very useful to be able to import files from any version of AutoCAD.
This error has been generated by the following steps:
1. Create a new Project
2. Import / Export
3.Import Layers from DWG/DXF
4.Drop-down window as shown in the attached image
Buenos días,
Utilizando QGIS en la versión 3.28.9 y la versión 3.32.1 he tenido el siguiente problema.
Al importar un archivo .dwg generado por AutoCAD, la aplicación, no es capaz de importar el archivo en versiones posteriores a la 2018.
¿Cómo podría importar un archivo de una versión más actual?
Sabiendo que la mayoría de los usuarios de AutoCAD utilizan versiones actuales con las herramientas más modernas, creo que sería muy útil poder importar archivos de cualquier versión de AutoCAD.
Este error se ha generado siguiendo los siguientes pasos:
1. Crear un nuevo Proyecto
2. Importar / Exportar
3. Importar Capas desde DWG/DXF
4. Ventana desplegable que aparece en la imagen adjunta
Adjunto imagen del error que se ha generado.
[cid:image003.png at 01D9DCDB.0DE54CA0]
Un saludo,
Javier Jiménez
[cid:image005.png at 01D9DCDB.0DE54CA0]
Javier Jiménez
Departamento de Desarrollo
Tel +34 683 554 229
Email jjimenez at proyectapv.com<mailto:jjimenez at proyectapv.com>
Web www.proyectapv.com<http://www.proyectapv.com/>
[Título: LinkedIn - Descripción: image of LinkedIn icon]<https://www.linkedin.com/in/javier-jimenez-del-val-5a1b2b216/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230901/6c8cc605/attachment-0001.htm>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230901/6c8cc605/attachment-0003.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230901/6c8cc605/attachment-0004.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230901/6c8cc605/attachment-0005.png>
More information about the QGIS-User
