[Qgis-user] Question Concerning Incorrect Color Shading in QGIS
Aqshems Nichols aqshems at berkeley.edu
Mon Sep 11 10:20:16 PDT 2023
Hello Adam,
Thank you for your response. I have posted a screenshot of the symbology
section:
[image: image.png]
Nonetheless, this is the output that I get when I apply the symbology:
[image: image.png]
I am still unsure of what is causing this issue so I look forward to
hearing back. Thank you again for your assistance!
Regards,
Aqshems
On Wed, Sep 6, 2023 at 8:09 AM Adam Nielsen <a.nielsen at shikadi.net> wrote:
> > The poverty rate layer is the only one displayed and has been assigned a
> > pink gradient. Nonetheless, the map displays colors completely different
> > than the gradient assigned. When I try to change the gradient to a
> > different color, the displayed color changes as well but it is still
> > incorrect. Does anyone know why this is happening and how to fix this
> > issue? Thank you for your consideration.
> Can you view the layer properties and look at the Symbology section,
> and maybe post a screenshot of that?
> QGIS has a few different places you can set a fill colour so it's
> possible that one of those settings is overriding your gradient.  You
> can have a look through all the settings in there and see if you can
> find where the actual colour you're seeing is set, and change that to
> 'none'.
> Also make sure you don't have any blending effects enabled (e.g. in the
> "Layer rendering" section at the bottom of the Symbology page).  These
> should all be set to 'normal' otherwise they can cause colour changes
> when they are rendered and mixed with whatever colour is behind the
> layer.
> Cheers,
> Adam.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/5c8eb245/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/5c8eb245/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/5c8eb245/attachment-0003.png>
More information about the QGIS-User mailing list
