[Qgis-user] Square Buffer
Hugh Kelley hghklly at gmail.com
Sat Sep 30 11:58:31 PDT 2023
Oops, including the list.
Also, having now written the response and re-read your question, I would
guess that the coordinate system you are using is causing the distortion
you see in the result.
I'd be curious to see what others on the list might suggest as the best
option for crs as I think even state plane would be distorted at least a
little.
Hi, not in front of my computer so I can't test but I would recommend
first, creating a round buffer with a diameter equal to the square side you
are looking for, and then second, using the "extent" tool that's in one of
the vector tools subcategories to extract the layer extent, creating the
square you need.
That should create a "square" although, importantly, the idea of a square
in the gis world is a little fraught as the coordinate system you are using
can sometimes produce odd results.
I would, at a minimum, use the measure tool to double check that what looks
like a square truly has a height equal to its width.
On Sat, Sep 30, 2023, 2:39 PM Michael Jabot via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> I apologize for posting what I think should be a simple task but I am
> stumped.
> I would like to create a 15 km square Buffer around a point for
> establishing a study site.
> I have used the buffer tool and set it to square and used 7.5 km as the
> distance. The buffer that is created is not square but instead is a longer
> on one set of sides.
> Again I apologize for bothering people with this ... thank you in advance
> for your help
> Mike
> Michael Jabot, Ph.D.
> SUNY Distinguished Professor, Science Education
> US Partner - NASA GLOBE Program
> NASA Earth Ambassador
> Director, Institute for Research in Science Teaching
> Chancellor's Award Recipient for Excellence in Research
> The State University of New York at Fredonia
> 716.320-0189 (Google Voice)
> jabot at fredonia.edu
> E250 Thompson Hall
> 280 Central Avenue
> Fredonia, NY  14063
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230930/0bc08167/attachment.htm>
More information about the QGIS-User mailing list
