[Qgis-user] Raster Merge issue
Irene McGoldrick muinteoirirenesnb at gmail.com
Tue Jan 23 00:25:45 PST 2024
I have no programming background, so please excuse me if this is an
incredibly basic question. I have tried turning it off and turning it back
on again.
I have been successfully merging raster layers over the past week using
Raster>Miscellaneous>Merge. It is no longer working for me. I can
achieve the same results by using Build Virtual Raster but I'd like to
understand what's happening and fix it if I can. I'm using the same raw
data to try to merge as I was successfully using during the week - nothing
has changed.
This is the error message I'm getting
QGIS version: 3.34.2-Prizren
QGIS code revision: 7d199797fcc
Qt version: 5.15.2
Python version: 3.9.5
GDAL version: 3.3.2
GEOS version: 3.9.1-CAPI-1.14.2
PROJ version: Rel. 8.1.1, September 1st, 2021
PDAL version: 2.3.0 (git-version: Release)
Algorithm started at: 2024-01-23T08:02:14
Algorithm 'Merge' starting…
Input parameters:
{ 'DATA_TYPE' : 5, 'EXTRA' : '', 'INPUT' :
['/Users/irenemcgoldrick/Documents/Lidar Raster Files/ASC raw
data/P_532746_dtm.asc','/Users/irenemcgoldrick/Documents/Lidar Raster
Files/ASC raw data/P_532748_dtm.asc'], 'NODATA_INPUT' : None,
'NODATA_OUTPUT' : None, 'OPTIONS' : '', 'OUTPUT' : 'TEMPORARY_OUTPUT',
'PCT' : False, 'SEPARATE' : False }
GDAL command:
gdal_merge.py -ot Float32 -of GMT -o
/private/var/folders/bk/m4zg7bwx7f771yq8hqsrddnr0000gn/T/processing_FDCMWO/f9a7599de3314675b6c81c21ebcb91bb/OUTPUT.nc
--optfile
/private/var/folders/bk/m4zg7bwx7f771yq8hqsrddnr0000gn/T/processing_FDCMWO/3ac083d5d1cf4635a258cc2fc63a6df1/mergeInputFiles.txt
GDAL command output:
Format driver GMT does not support creation and piecewise writing.
Please select a format that does, such as GTiff (the default) or HFA (Erdas
Imagine).
Process returned error code 1
Execution completed in 0.54 seconds
Results:
{'OUTPUT':
'/private/var/folders/bk/m4zg7bwx7f771yq8hqsrddnr0000gn/T/processing_FDCMWO/f9a7599de3314675b6c81c21ebcb91bb/OUTPUT.nc'}
Loading resulting layers
The following layers were not correctly generated.
You can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm.
In the log I am getting a message
2024-01-22T17:23:37     INFO    No module named 'remotior_sensus'
Also
2024-01-22T17:23:39     WARNING    Semi-Automatic Classification Plugin :
Warning. Python library remotior_sensus was not found and was automatically
downloaded, but SCP may not work properly. Please, install the required
Python library remotior_sensus following the user manual.
Not sure if they are related or not. I have uninstalled and re-installed
the Semi Automatic Classification Plugin. I'm working off Mac OS. I have
tried searching remotior_sensus in the user manual but I'm not getting
anything back for it.
Any help much appreciated.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240123/8a914fc5/attachment.htm>
More information about the QGIS-User mailing list
