[Qgis-user] How to Change Layer coordinate fields
Nigel Berjak nigel at s3.co.za
Wed Jan 24 02:20:51 PST 2024
Hi Alanna
You may be able to, although unconfirmed on my side, use the
changeDataSource plugin, which gives you the fields being referenced I
believe, to change the names. It may be worth tinkering with if no other
concrete solutions are found. I may only be able to check if this does
work, tomorrow.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-01-24 11:54, Alanna Mitchell via QGIS-User wrote:
> Dear group,
> I have a qgis project I have been working on. It was point data
> uploaded as a delimited text layer, and in the excel file (.csv) I have
> the data in lat/long and easting/northing (irish transverse mercator)
> and I haven't opened it in a while, but when I did it changed one of
> the fields to longtidue, so now one is projecting in easting and one in
> longitude. I wish to alter this from the actual file, I don't want to
> reupload it again as I have a lot of project layouts saved that I only
> need to alter the symbology on and resave. I haven't been able to
> figure this out. In my excel file I have the coordinates, so I wish to
> change the column the field is derived from. Is this possible? When I
> hover over the layer on QGIS, I can see the file path so even if I had
> a way to access this and change it, I think I would manage. Thank you
> for any help. Kind regards.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240124/0530247e/attachment.htm>
More information about the QGIS-User mailing list
