[Qgis-user] QGIS and FileGDB
Totò Fiandaca
pigrecoinfinito at gmail.com
Sun Mar 10 11:37:39 PDT 2024
Thanks Andrea for the details.
I will try to understand a little better and study the phenomenon carefully
so that I can better detail the problem.
thank you all.
I always use OSgeo4W, the data update that caused me to lose the data was
done via the field calculator.
Il giorno sab 9 mar 2024 alle ore 09:21 Andrea Giudiceandrea via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> > Totò Fiandaca pigrecoinfinito at gmail.com
> > Tue Mar 5 00:15:20 PST 2024
> > I noticed that by modifying
> > the FileGDBs created by ArcGIS PRO in QGIS:
> > 1. saving is particularly slow;
> > 2. I often lose data, i.e. if I have an active data selection and I try
> to
> > update only the selection, QGIS updates the entire dataset resulting in
> > data loss.
> Hi Totò,
> as you already know, QGIS handles ESRI File Geodatabase layer via the
> GDAL/OGR library.
> The GDAL/OGR library has two different drivers for the ESRI File
> Geodatabase forma: the built-int driver "OpenFileGDB" [1] (which is
> available on all systems) and the "FileGDB" driver (available on Windows
> through OSGeo4W) which depends on the ESRI FileGDB API SDK [2].
> Using which driver does the issue occurs?
> How do you update the data?
> I think you should inform the GDAL/OGR developers about the issue. Since
> you experience the issue often, it shouldn't be so difficult to provide
> a sample ESRI File Geodatabase layer and exact steps in order to
> replicate the issue.
> Best regards.
> [1] https://gdal.org/drivers/vector/openfilegdb.html
> [2] https://gdal.org/drivers/vector/filegdb.html
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
*Ing. Salvatore Fiandaca*
*mobile*.:+39 327.493.8955
*m*: *pigrecoinfinito at gmail.com <pigrecoinfinito at gmail.com>*
*C.F*.: FNDSVT71E29Z103G
*P.IVA*: 06597870820
*membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
*socio GFOSS.it - *http://gfoss.it/
*member OSGeo* - *https://www.osgeo.org/member/fiandaca/*
<https://www.osgeo.org/member/fiandaca/>
*blog:*
* https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
- https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
<https://www.facebook.com/qgis.it/> *
*TW: <http://goog_95411464>**https://twitter.com/totofiandaca
<https://twitter.com/totofiandaca>*
43°51'0.54"N 10°34'27.62"E - EPSG:4326
“Se la conoscenza deve essere aperta a tutti,
perchè mai limitarne l’accesso?”
R. Stallman
Questo documento, allegati inclusi, contiene informazioni di proprietà di
FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
in relazione alle finalità per le quali è stato ricevuto. E' vietata
qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di
informare tempestivamente il mittente e distruggere la copia in proprio
possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240310/111cbc9f/attachment.htm>
More information about the QGIS-User
