[Qgis-user] Multiple styles saved in database, how to choose one?
Richard Duivenvoorde rdmailings at duif.net
Fri Mar 15 03:58:27 PDT 2024
Ah! Thanks, found it now! I was apparently to eager to find a dropdown somewhere in my UI :-)
Besides your solution you also get the list in a little table when you go to the Layer Styling Panel, select the 'Style Manager' tab there and the choose 'Load style', and then select the 'From datasource database' option...
Regards,
PS: still would like to restructure the style menu a little: maybe add the option Copy All STyle Categories (so no need to open the next level), and 'Use Style' (only in case there are saved styles in the db... But: future :-)
On 3/15/24 11:31 AM, Richard McDonnell wrote:
> Hi Richard,
> You can indeed load others.
>  From the layer properties, select the style button, usually bottom left. Then select Load Styles, all other styles in the database will be listed there. You can select any other ones you set up for that layer from there.
> Kind Regards,
> Richard.
Name: Screenshot from 2024-03-15 11-55-02.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/38b79353/attachment-0001.png>
More information about the QGIS-User mailing list
