[Qgis-user] Atlas - Map series along linear object
Werner Macho werner.macho at gmail.com
Tue Mar 26 03:39:54 PDT 2024
Hi Michaela,
I once wrote the PolyStrip Plugin to create overlapping polygons along a
path and did the same you want to archieve using this created polygons (if
i remember correct I also calculated the rotation - so it was fairly easy
to use either landscape or portrait and rotate the north arrow along).
https://plugins.qgis.org/plugins/polystrip/
It's just - I think I have not used this plugin since a very long time and
also did not update it recently - so I don't know if it still works - but
it could be a start for what you want to do.
I do not have an example yet (@work) but somewhere at home I should have a
project using this to create what it sounds like is what you are looking
for.
But I think you could tinker around a bit and I am sure you will soon find
a way how to use the polygons (as long as the plugin still works ;) )
Hope this helps a bit getting you started.
regards
Werner
On Tue, Mar 26, 2024 at 11:27 AM Huesmann, Michaela via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> I would like to create a series of maps using the atlas function and have
> already experimented and watched videos. What I'm still missing is an
> example of how I can create a series of maps along a linear object. E.g. a
> series of maps at a scale of 1:500 with sections along a street.
>    1. How to prepare the covering layer along the road?
>    1. Can I use the same layout, e.g. A3 landscape, for all partial maps
>    and rotate the sections so that they are placed as horizontally as possible
>    on the map frame? Then of course an automatically adjusted north arrow is
>    also necessary.
>    1. Or is 2. not possible with rotation and I then have to choose
>    landscape or portrait format depending on the position of the section in
>    the north orientation? I can then probably use the coverage layer to
>    determine the vertical or transverse extent of the section and then select
>    the respective side orientation.
> Who has experience with the atlas along a line object and can help me?
> Thanks and best regards,
> Michaela
> [image: Kreisstadt Steinfurt] <http://www.steinfurt.de>
>  - 48565 Steinfurt
> www.steinfurt.de
> Mit freundlichen Grüßen
> im Auftrag
> Michaela Huesmann
> Geodaten
> Fachdienst Tiefbau
> Tel.: +49 2552 925 219
> Fax:
> E-Mail: michaela.huesmann at Stadt-Steinfurt.de
> Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240326/4abf5506/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240326/4abf5506/attachment.jpe>
More information about the QGIS-User mailing list
