[Qgis-user] Atlas - Map series along linear object
Jorge Gustavo Rocha jgr at geomaster.pt
Tue Mar 26 03:54:06 PDT 2024
Hi Michaela,
You can use the tool "points along geometry" to create the coverage
layer. Choose the correct distance based on your 1:500 scale (to show
more or less overlapping areas). Then create the Atlas using such points
(that you can hide them in the output). You can play with different
distances.
I hope it helps,
Jorge
On 26/03/24 10:26, Huesmann, Michaela via QGIS-User wrote:
> Hello,
> I would like to create a series of maps using the atlas function and
> have already experimented and watched videos. What I'm still missing
> is an example of how I can create a series of maps along a linear
> object. E.g. a series of maps at a scale of 1:500 with sections along
> a street.
>  1. How to prepare the covering layer along the road?
>  2. Can I use the same layout, e.g. A3 landscape, for all partial maps
>     and rotate the sections so that they are placed as horizontally as
>     possible on the map frame? Then of course an automatically
>     adjusted north arrow is also necessary.
>  3. Or is 2. not possible with rotation and I then have to choose
>     landscape or portrait format depending on the position of the
>     section in the north orientation? I can then probably use the
>     coverage layer to determine the vertical or transverse extent of
>     the section and then select the respective side orientation.
> Who has experience with the atlas along a line object and can help me?
> Thanks and best regards,
> Michaela
> Kreisstadt Steinfurt <http://www.steinfurt.de>
>  - 48565 Steinfurt
> www.steinfurt.de <http://www.steinfurt.de>
> Mit freundlichen Grüßen
> im Auftrag
> MichaelaHuesmann
> Geodaten
> Fachdienst Tiefbau
> Tel.: +49 2552 925 219
> Fax:
> E-Mail: michaela.huesmann at Stadt-Steinfurt.de
> <mailto:michaela.huesmann at Stadt-Steinfurt.de>
> Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240326/fe72b17d/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240326/fe72b17d/attachment.jpe>
More information about the QGIS-User mailing list
