[OSGeo-Conf] the board passed a motion to award FOSS4G 2015 to South-Korea
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri May 16 04:19:54 PDT 2014
Congratulations Sanghee and team!
As Cameron mentioned, drafting your press releases on the OSGeo wiki is
very useful in the long run. Be sure to include the text
"[[Category:FOSS4G2015]]" at the bottom of every wiki page you create,
and it will magically appear on this page:
http://wiki.osgeo.org/wiki/Category:FOSS4G2015
Congrats again! Let me/us know if you need anything.
-jeff
On 2014-05-15, 7:02 PM, Cameron Shorter wrote:
> Hi Sanghee,
> Congratulations.
> One organisation tool which have worked well for prior FOSS4G events is
> to set up a wiki to collect your ideas as you go along. It can start out
> small and you can then fill in content as the conference gets closer.
> The wiki we used for foss4g 2009 is at:
> http://wiki.osgeo.org/wiki/FOSS4G_2009
> In particular, we found it very useful for collaboratively creating
> press releases, which then becomes an archive after the press release
> was put out. (You might find it useful to refer back to prior press
> releases when crafting your own press release.)
> Here are the 2009 press releases:
> http://wiki.osgeo.org/wiki/FOSS4G_2009_Press_Releases
> And I confirm that I'm happy to help review your press release if you wish.
> On 16/05/2014 6:43 am, Bart van den Eijnden wrote:
>> Hi Sanghee,
>> congratulations, the board has just passed a motion to award FOSS4G
>> 2015 to South-Korea. The exact text of the motion was:
>> Motion: accept the Korean proposal for foss4g 2015, under the proviso
>> that the budget is revisited and concerns raised are considered.
>> Next step is to create a press release. Are you able to draft up a
>> press release (maybe you want to wait until you have a basic website
>> up and running, I’ll defer to you on that) and get it to Cameron and
>> Jeff (CC-ed) for review? TIA.
>> Best regards,
>> Bart
More information about the Conference_dev
