[OSGeo-Conf] OSGeo Code of Conduct, version 1.0rc1
Cameron Shorter cameron.shorter at gmail.com
Wed May 13 13:55:51 PDT 2015
Hi Kristin,
Thanks for your review and tweaks.
The CoC as it stands does have a light weight implementation guide, and
escalation process. This hopefully should catch 95% of scenarios.
One think I liked about the Geek Feminism Wiki was their internal
guidelines for conference staff implementing an anti-harassment policy.
http://geekfeminism.wikia.com/wiki/Conference_anti-harassment_policy
If you are inspired, and think it appropriate, you might want to
customise it to fit within the FOSS4G Handbook format:
http://wiki.osgeo.org/wiki/FOSS4G_Handbook
Warm regards,
Cameron
On 14/05/2015 4:10 am, Camille Acey wrote:
> Yes, Kristin, I agree, and I am definitely on board for the (likely
> more involved) question of implementation. Keep me posted!
> Thanks all,
> Camille
> Camille E. Acey
> Manager, Customer Development and Partnerships| Boundless
> camille at boundlessgeo.com <mailto:camille at boundlessgeo.com>
> T: +1 917.460.7197|M: +1 347.267.2016| Skype: camilleacey
> New York, NY - USA
> @boundlessgeo
> <https://twitter.com/boundlessgeo>
> On Wed, May 13, 2015 at 2:05 PM, Kristin Bott <bottk at reed.edu
> <mailto:bottk at reed.edu>> wrote:
>     Cameron,
>     Some minor edits to the language under "Application" --
>     http://wiki.osgeo.org/wiki/Code_Of_Conduct#Application
>     I assume that the next step in the CoC discussion, after the CoC
>     is approved, is how to implement the CoC. (Methods for dealing
>     with violations -- are those in the hands of the project admins /
>     event organizers, is there an OSGeo-wide involvement, etc...)
>     I imagine that hashing out those types of details will be a fairly
>     involved process -- step one, of course, is to get the CoC
>     approved. Thanks again for all your work on this.
>     -kb
>     On Tue, May 12, 2015 at 2:31 PM, Cameron Shorter
>     <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>         Following on from the IRC meeting today,
>         It was agreed by all participants that the proposed Code of
>         Conduct should be adopted, with the following changes:
>         * A statement explaining how the CoC should be applied, as
>         suggested by Kristin Bott (below)
>         * Remove negative words from the Diversity Statement, as
>         suggested by Jeff McKenna
>         * Move to a Code of Conduct URL (instead of Diversity URL)
>         I've addressed each of these into
>         Kristin,
>         Your suggested has been added as:
>         Can you please confirm that this addresses what you were
>         thinking, or suggest alternative wording.
>         Are there any further comments or suggestions before we ask
>         the board to endorse it?
>         Warm regards,
>         Cameron
>         On 13/05/2015 3:56 am, Kristin Bott wrote:
>>         Hi all,
>>         Apologies for my slow response -- Cameron, this looks good to
>>         me; thank you for the effort and time it took to put this
>>         together, including reaching out to a number of different
>>         people and incorporating their perspectives.
>>         I won't be able to make the related meeting, unfortunately.
>>         Thanks to all who are contributing to this effort.
>>         I note that there is no central / suggested / mandated way to
>>         publicize the CoC for a given event or group; this puts the
>>         onus on individual organizers / LOCs / etc to make the CoC
>>         visible and enforced. I look forward to seeing this (or a
>>         revision thereof) CoC featured as part of upcoming OSGeo events.
>>         cheers -
>>         - kristin
>>         On Sun, May 10, 2015 at 8:07 AM, Eli Adam
>>         <eadam at co.lincoln.or.us <mailto:eadam at co.lincoln.or.us>> wrote:
>>             Hi Cameron and all,
>>             On May 10, 2015 3:44 AM, "Cameron Shorter"
>>             > Members of the conference committee,
>>             Or anyone participating (but yes especially conference
>>             committee members)
>>             > I haven't heard anything positive or negative about the proposed OSGeo
>>             Code of Conduct [2], and only a couple of people planning
>>             to attend the IRC meeting to discuss it.
>>             > I'm hoping that is because interested people have read
>>             it, think it is acceptable, and don't have anything else
>>             to add?
>>             Yes for me but always interested in hearing from others.
>>             > If you have read the Code of Conduct, and think it is suitable to be applied
>>             to future OSGeo projects and FOSS4G events then please
>>             speak up with your support or recommended suggestions for
>>             changes.
>>             I think the we did a good job sorting through other
>>             comparable codes of conduct and finding where the best
>>             aspects came together.   Cameron also did a lot to keep
>>             the conversation going and not getting too distracted
>>             with minor details. Cameron also did a lot to try and
>>             incorporate various disparate views which is not an easy
>>             task. Thanks for that.
>>             Best regards,  Eli
>>             > Thanks in advance, Cameron
>>             > On 2/05/2015 9:03 am, Cameron Shorter wrote:
>>             >> All,
>>             >> There has been a lot of valuable discussion around the
>>             development of an OSGeo Code of Conduct / Diversity
>>             Statement earlier this year, mainly on the OSGeo
>>             Conference and OSGeo Board email lists.
>>             >> I've researched a number of prior Code of Conduct and
>>             Diversity Statements and combined with OSGeo participant
>>             comments to build a draft OSGeo Code of Conduct, along
>>             with references to prior material, comments, and a list
>>             of goals we want to achieve from such a document.
>>             >> I propose that we aim to finalise a 1.0 version of an
>>             OSGeo Code of Conduct/Diversity Statement and provide a
>>             recommendation for the next OSGeo board meeting on 21 May
>>             2015.
>>             >> I've set up a Doodle Pole for an IRC meeting aimed at
>>             finalising this Code of Conduct [1]
>>             >> If you would like to contribute, please:
>>             >> 1. Read the draft code of conduct [2]
>>             >> 2. Provide comments either in the comments section on
>>             the wiki [3] or on the conference email list [4]
>>             >> 3. Register for [1] and then attend the IRC meeting [5]
>>             >> [1] http://doodle.com/k8bmu6e8kntht462
>>             >> [2] http://wiki.osgeo.org/wiki/Diversity
>>             >> [3]
>>             http://wiki.osgeo.org/wiki/Diversity#Community_Comments
>>             >> [4] http://lists.osgeo.org/mailman/listinfo/conference_dev
>>             >> [5] irc://freenode.net#osgeo <http://freenode.net#osgeo>
>>             >> Warm regards,
>>             > Cameron Shorter,
>>             > Software and Data Solutions Manager
>>             > LISAsoft
>>             > Suite 112, Jones Bay Wharf,
>>             > 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>             > P +61 2 9009 5000 <tel:%2B61%202%209009%205000>, W
>>             www.lisasoft.com <http://www.lisasoft.com>, F +61 2 9009
>>             5099 <tel:%2B61%202%209009%205099>
>>             > _______________________________________________
>>             > Conference_dev mailing list
>>             > Conference_dev at lists.osgeo.org
>>             <mailto:Conference_dev at lists.osgeo.org>
>         Cameron Shorter,
>         LISAsoft
>         P+61 2 9009 5000  <tel:%2B61%202%209009%205000>,  Wwww.lisasoft.com  <http://www.lisasoft.com>,  F+61 2 9009 5099  <tel:%2B61%202%209009%205099>
>     Conference_dev at lists.osgeo.org <mailto:Conference_dev at lists.osgeo.org>
Cameron Shorter,
LISAsoft
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20150514/652b3528/attachment-0001.html>
More information about the Conference_dev mailing list
