[OSGeo-Conf] Implementation plan for OSGeo CoC -- call for volunteers [[was OSGeo Code of Conduct, version 1.0rc1 ]]
Kristin Bott
bottk at reed.edu
Wed May 13 14:18:01 PDT 2015
Hi all --
See Cameron's note below re: the current draft OSGeo CoC and some options
for implementation.
Camille Acey and I will be working on this, and if other folks are
interested in joining in, it would be great to move this forward.
If interested, ping me off list.
cheers -
-kristin
On Wed, May 13, 2015 at 1:55 PM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> Hi Kristin,
> Thanks for your review and tweaks.
> The CoC as it stands does have a light weight implementation guide, and
> escalation process. This hopefully should catch 95% of scenarios.
> One think I liked about the Geek Feminism Wiki was their internal
> guidelines for conference staff implementing an anti-harassment policy.
> http://geekfeminism.wikia.com/wiki/Conference_anti-harassment_policy
> If you are inspired, and think it appropriate, you might want to customise
> it to fit within the FOSS4G Handbook format:
> http://wiki.osgeo.org/wiki/FOSS4G_Handbook
> Warm regards,
> Cameron
> On 14/05/2015 4:10 am, Camille Acey wrote:
> Yes, Kristin, I agree, and I am definitely on board for the (likely more
> involved) question of implementation. Keep me posted!
> Thanks all,
> Camille
> Camille E. Acey
> Manager, Customer Development and Partnerships| Boundless
> camille at boundlessgeo.com
> T: +1 917.460.7197|M: +1 347.267.2016| Skype: camilleacey
> New York, NY - USA
> @boundlessgeo
> <https://twitter.com/boundlessgeo>
> On Wed, May 13, 2015 at 2:05 PM, Kristin Bott <bottk at reed.edu> wrote:
>> Cameron,
>> Some minor edits to the language under "Application" --
>> http://wiki.osgeo.org/wiki/Code_Of_Conduct#Application
>> I assume that the next step in the CoC discussion, after the CoC is
>> approved, is how to implement the CoC. (Methods for dealing with violations
>> -- are those in the hands of the project admins / event organizers, is
>> there an OSGeo-wide involvement, etc...)
>> I imagine that hashing out those types of details will be a fairly
>> involved process -- step one, of course, is to get the CoC approved. Thanks
>> again for all your work on this.
>> -kb
>> On Tue, May 12, 2015 at 2:31 PM, Cameron Shorter <
>> cameron.shorter at gmail.com> wrote:
>>> Following on from the IRC meeting today,
>>> It was agreed by all participants that the proposed Code of Conduct
>>> should be adopted, with the following changes:
>>> * A statement explaining how the CoC should be applied, as suggested by
>>> Kristin Bott (below)
>>> * Remove negative words from the Diversity Statement, as suggested by
>>> Jeff McKenna
>>> * Move to a Code of Conduct URL (instead of Diversity URL)
>>> I've addressed each of these into
>>> Kristin,
>>> Your suggested has been added as:
>>> Can you please confirm that this addresses what you were thinking, or
>>> suggest alternative wording.
>>> Are there any further comments or suggestions before we ask the board to
>>> endorse it?
>>> Warm regards,
>>> Cameron
>>> On 13/05/2015 3:56 am, Kristin Bott wrote:
>>> Hi all,
>>> Apologies for my slow response -- Cameron, this looks good to me;
>>> thank you for the effort and time it took to put this together, including
>>> reaching out to a number of different people and incorporating their
>>> perspectives.
>>> I won't be able to make the related meeting, unfortunately. Thanks to
>>> all who are contributing to this effort.
>>> I note that there is no central / suggested / mandated way to
>>> publicize the CoC for a given event or group; this puts the onus on
>>> individual organizers / LOCs / etc to make the CoC visible and enforced. I
>>> look forward to seeing this (or a revision thereof) CoC featured as part of
>>> upcoming OSGeo events.
>>> cheers -
>>> - kristin
>>> On Sun, May 10, 2015 at 8:07 AM, Eli Adam <eadam at co.lincoln.or.us>
>>> wrote:
>>>> Hi Cameron and all,
>>>> On May 10, 2015 3:44 AM, "Cameron Shorter" <cameron.shorter at gmail.com>
>>>> wrote:
>>>> > Members of the conference committee,
>>>> Or anyone participating (but yes especially conference committee
>>>> members)
>>>> > I haven't heard anything positive or negative about the proposed
>>>> OSGeo Code of Conduct [2], and only a couple of people planning to attend
>>>> the IRC meeting to discuss it.
>>>> > I'm hoping that is because interested people have read it, think it
>>>> is acceptable, and don't have anything else to add?
>>>> Yes for me but always interested in hearing from others.
>>>> > If you have read the Code of Conduct, and think it is suitable to be
>>>> applied to future OSGeo projects and FOSS4G events then please speak up
>>>> with your support or recommended suggestions for changes.
>>>> I think the we did a good job sorting through other comparable codes of
>>>> conduct and finding where the best aspects came together. Cameron also
>>>> did a lot to keep the conversation going and not getting too distracted
>>>> with minor details. Cameron also did a lot to try and incorporate various
>>>> disparate views which is not an easy task. Thanks for that.
>>>> Best regards, Eli
>>>> > Thanks in advance, Cameron
>>>> > On 2/05/2015 9:03 am, Cameron Shorter wrote:
>>>> >> All,
>>>> >> There has been a lot of valuable discussion around the development
>>>> of an OSGeo Code of Conduct / Diversity Statement earlier this year, mainly
>>>> on the OSGeo Conference and OSGeo Board email lists.
>>>> >> I've researched a number of prior Code of Conduct and Diversity
>>>> Statements and combined with OSGeo participant comments to build a draft
>>>> OSGeo Code of Conduct, along with references to prior material, comments,
>>>> and a list of goals we want to achieve from such a document.
>>>> >> I propose that we aim to finalise a 1.0 version of an OSGeo Code of
>>>> Conduct/Diversity Statement and provide a recommendation for the next OSGeo
>>>> board meeting on 21 May 2015.
>>>> >> I've set up a Doodle Pole for an IRC meeting aimed at finalising
>>>> this Code of Conduct [1]
>>>> >> If you would like to contribute, please:
>>>> >> 1. Read the draft code of conduct [2]
>>>> >> 2. Provide comments either in the comments section on the wiki [3]
>>>> or on the conference email list [4]
>>>> >> 3. Register for [1] and then attend the IRC meeting [5]
>>>> >> [1] http://doodle.com/k8bmu6e8kntht462
>>>> >> [2] http://wiki.osgeo.org/wiki/Diversity
>>>> >> [3] http://wiki.osgeo.org/wiki/Diversity#Community_Comments
>>>> >> [4] http://lists.osgeo.org/mailman/listinfo/conference_dev
>>>> >> [5] irc://freenode.net#osgeo
>>>> >> Warm regards,
>>>> > Cameron Shorter,
>>>> > Software and Data Solutions Manager
>>>> > LISAsoft
>>>> > Suite 112, Jones Bay Wharf,
>>>> > 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>>> > P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>>>> > _______________________________________________
>>>> > Conference_dev mailing list
>>>> > Conference_dev at lists.osgeo.org
>>> Cameron Shorter,
>>> LISAsoft
> Cameron Shorter,
> LISAsoft
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20150513/feed8df6/attachment-0001.html>
More information about the Conference_dev
