[OSGeo-Conf] [Board] MOTION : Conference Committee - Updating Membership Policies and Process
Cameron Shorter cameron.shorter at gmail.com
Thu Sep 22 04:12:23 PDT 2016
Thanks Maria for pointing out the 100% quorum from the board processes.
I'm supportive of your suggestion for using the board voting procedures
with the 50% quorum amendment.
Warm regards, Cameron
On 22/09/2016 9:05 AM, Darrell Fuhriman wrote:
> Oh yah, I guess I overlooked that bit.
> I agree that 100% for a quorum is unnecessary and 50% seems reasonable
> to me.
> d.
>> On Sep 21, 2016, at 14:38, Maria Antonia Brovelli
>> <maria.brovelli at polimi.it <mailto:maria.brovelli at polimi.it>> wrote:
>> This requires that ALL members vote, i.e. quorum = 100 %.   A
>> minimum 50 % quorum is milder and takes into account that for some
>> reason some of the members don't have the possibility of voting. I
>> prefer  this second option.
>> Therefore I'm positive with the proposal adding the 50 % quorum.
>> Best.
>> Maria
>> *Prof. Maria Antonia Brovelli
>> Vice Rector for Como Campus and GIS Professor
>> Politecnico di Milano
>> ISPRS WG IV/4"Collaborative crowdsourced cloud mapping
>> (C3M)";OSGeo;ICA-OSGeo-ISPRS Advisory Board; NASA WorldWind Europa
>> Challenge;SIFET
>> *SolKatzAward2015*
>> Via Natta, 12/14 - 22100 COMO (ITALY)
>> Tel. +39-031-3327336 - Mob.+39-328-0023867 -fax.+39-031-3327321
>> e-mail1: maria.brovelli at polimi.it <mailto:maria.brovelli at polimi.it>
>> e-mail2:prorettrice at como.polimi.it <mailto:prorettrice at como.polimi.it>
>> *Da:*Conference_dev <conference_dev-bounces at lists.osgeo.org
>> <mailto:conference_dev-bounces at lists.osgeo.org>> per conto di Cameron
>> Shorter <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>>
>> *Inviato:*mercoledì 21 settembre 2016 22.50
>> *A:*Darrell Fuhriman; massimiliano cannata
>> *Cc:*<conference_dev at lists.osgeo.org
>> <mailto:conference_dev at lists.osgeo.org>>
>> *Oggetto:*Re: [OSGeo-Conf] [Board] MOTION : Conference Committee -
>> Thanks Maxi for the suggestion. I like it.
>> I agree that the board voting processes are good. I'd actually prefer
>> to use them as written, without addition of a mention of "needing 50%
>> of members to vote".
>> My reasons:
>> 1. It retains consistency between committees.
>> 2. It will still work within a weakened committee (with many inactive
>> members)
>> Maria, Venka, others,
>> Do you have any objections to adopting board voting procedures?
>> On 22/09/2016 1:48 AM, Darrell Fuhriman wrote:
>>> This seems perfectly reasonable to me.
>>> d.
>>>> On Sep 21, 2016, at 05:50, massimiliano cannata
>>>> <massimiliano.cannata at gmail.com
>>>> <mailto:massimiliano.cannata at gmail.com>> wrote:
>>>> Hi Cameron and Steven,
>>>> as a suggestion why don't you take the well tested procedure
>>>> adopted at board level [1]?
>>>> (And herein after reported for shake of semplicity...)
>>>>   Board Voting Procedure
>>>>     Purpose
>>>> This document explains the voting procedure for motions put forward
>>>> to the OSGeo Board of Directors.
>>>>     Voting Process
>>>>   * Board voting occurs during monthly meetings, as well as a
>>>>     followup vote through email
>>>>   * each Board member may vote “+1” to indicate support for the motion.
>>>>   * each Board member may vote “-1” to veto a motion, but must
>>>>     provide clear reasoning and alternate approaches to resolving
>>>>     the problem within the two business days.
>>>>   * A vote of "-0" indicates mild disagreement, but has no effect.
>>>>     A "0" indicates no opinion. A "+0" indicate mild support, but
>>>>     has no effect.
>>>>   * A motion will be passed once all of the Board members place a
>>>>     vote, and no vetoes are received (-1).
>>>>   * If a motion is vetoed, and it cannot be revised to satisfy all
>>>>     parties, then it can be resubmitted for an override vote, in
>>>>     which a majority of all Board members indicating +1 is required
>>>>     to pass it.
>>>> Maybe you could change "A motion will be passed once all of the
>>>> Board members place a vote" with "A motion will be passed once 50%
>>>> of the Board members place a vote"...
>>>> Best,
>>>> Maxi
>>>> [1]https://wiki.osgeo.org/wiki/Board_Voting_Procedure
>>>> 2016-09-21 13:58 GMT+02:00 Cameron
>>>> Shorter<cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>>:
>>>>     Hi Maria,
>>>>     I think we need to ensure that any rules we put in place will
>>>>     be viable under both robust and weakened committees. A simple
>>>>     test is "Would these guidelines work within a flagging
>>>>     committee?" Eg: What if 8 out of 11 of the members have become
>>>>     inactive and are uncontactable? Would these guidelines still work?
>>>>     Note also that committee members are volunteers and we can't
>>>>     "require" them to vote. We can "request" they vote, maybe even
>>>>     go as far as "expecting" them to vote.
>>>>     I'll propose alternative text. As it stands, I think Steven's
>>>>     words are a better starting point to work from. (I'm aware he
>>>>     put a lot of time into it, and it went through a number of
>>>>     iterations of reviews, which is partly why I think it is well
>>>>     worded).
>>>>     Suggested alternative text (which includes the 50% of members
>>>>     voting):
>>>>     /Everyday topics will be decided upon by an open vote of all
>>>>     committee members in a clearly designated separate mail thread
>>>>     (+1/-1) over a minimum of two business days. We will aim to
>>>>     ensure at least 50% of members vote. Ideally we aim for
>>>>     consensus falling back on simple majority vote where necessary.
>>>>     The result will be clearly declared afterwards (or whatever is
>>>>     decided)./
>>>>     On 21/09/2016 5:06 PM, Maria Antonia Brovelli wrote:
>>>>>     Below my first motion about voting motions
>>>>>     When a motion is presented, a quorum of 50% has to be reached
>>>>>     in order to consider valid the vote. Reached this threshold,
>>>>>     the majority rule is adopted.
>>>>>     If there is no majority consensus, the members who didn't vote
>>>>>     are required to vote ( ar least one of them). In case of
>>>>>     parity,  the motion is discussed again until a convergence is
>>>>>     found.
>>>>>     If anyone has more comments or suggestions that they wish to
>>>>>     make please get them by 18.00 GMT on 22nd September. Voting
>>>>>     the motion will be open then and up to 25 September 18 pm.
>>>>>     Cheers
>>>>>     Maria
>>>>>     Sent from my Samsung device
>>>>>     -------- Original message --------
>>>>>     From: Steven Feldman<shfeldman at gmail.com>
>>>>>     <mailto:shfeldman at gmail.com>
>>>>>     Date: 20/09/2016 20:25 (GMT+01:00)
>>>>>     To: Maria Antonia Brovelli<maria.brovelli at polimi.it>
>>>>>     Cc: conference<conference_dev at lists.osgeo.org>
>>>>>     Subject: Re: [OSGeo-Conf] [Board] MOTION : Conference
>>>>>     Thanks Maria
>>>>>     I support a >50% must vote and the majority of the voters to
>>>>>     decide. Did you mean to not have a veto in CC voting?
>>>>>     Can you redraft the motion and post the new motion as a new
>>>>>     thread for people to comment on with a cutoff when voting starts
>>>>>     ______
>>>>>     Steven
>>>>>>     On 20 Sep 2016, at 19:12, Maria Antonia Brovelli
>>>>>>     wrote:
>>>>>>     If we are speaking about less than one vote per month,
>>>>>>     probably it is not so hard for at least the half of the
>>>>>>     people to vote.
>>>>>>     I propose again formally:  quorum at 50% and majority for the
>>>>>>     acceptance of the motion.
>>>>>>     Many thanks for everything.
>>>>>>     Maria
>>>>>>     From: Steven Feldman <shfeldman at gmail.com
>>>>>>     <mailto:shfeldman at gmail.com>>
>>>>>>     Date: 20/09/2016 11:51 (GMT+01:00)
>>>>>>     To: Maria Antonia Brovelli <maria.brovelli at polimi.it
>>>>>>     Cc: conference <conference_dev at lists.osgeo.org
>>>>>>     Maria
>>>>>>     There are very few votes in the CC, I am not sure of the
>>>>>>     exact number but I would guess that it is less than 10 per year.
>>>>>>     The votes that I recall in the last year have been to appoint
>>>>>>     you and Till as members of the committee, to appoint me as
>>>>>>     chairman and the votes for the 2 stages of the 2017 RfP
>>>>>>     process. Perhaps someone else can correct me?
>>>>>>     I am going to back out of this discussion until others to
>>>>>>     propose an alternative if they wish.
>>>>>>     ______
>>>>>>     Steven
>>>>>>>     On 20 Sep 2016, at 10:32, Maria Antonia Brovelli
>>>>>>>     wrote:
>>>>>>>     Dear Steven, as already said I don't agree on the voting
>>>>>>>     mechanism and, as you have seen, there is not a consensus. I
>>>>>>>     prefer that we before "solve" this question.
>>>>>>>     And sorry for asking you again, you who have been doing so
>>>>>>>     much work for this Committee ( thanks a lot!!!): nobody
>>>>>>>     answered me about how many motions were voted in the last
>>>>>>>     year. I want to put myself in  Cameron's clothes ( literally
>>>>>>>     translated from italian; ��probably in English you don't
>>>>>>>     have this expression. In any case it is like "point of
>>>>>>>     view") and understand pragmatically how much commitment was
>>>>>>>     and is implied with respect to voting.
>>>>>>>     Thanks again and have a nice day
>>>>>>>     Maria
>>>>>>>     Date: 19/09/2016 23:16 (GMT+01:00)
>>>>>>>     <mailto:maria.brovelli at polimi.it>>, Venka
>>>>>>>     <venka.osgeo at gmail.com <mailto:venka.osgeo at gmail.com>>
>>>>>>>     Cc:board at lists.osgeo.org <mailto:board at lists.osgeo.org>,
>>>>>>>     <mailto:conference_dev at lists.osgeo.org>>, Cameron Shorter
>>>>>>>     Maria (and Venka)
>>>>>>>     My problem is that there are now 77 mails in this thread and
>>>>>>>     I am not sure whether you and Venka voted against our
>>>>>>>     vetoed. If you did veto, how do the substantial majority of
>>>>>>>     the committee who voted in favour find a way to resolve?
>>>>>>>     To me this doesn't seem a very effective way of reaching a
>>>>>>>     decision on a relatively minor procedural change which
>>>>>>>     apparently is not very different to the procedures in some
>>>>>>>     other committees.
>>>>>>>     Steven
>>>>>>>     07958 924 101
>>>>>>>     On 19 Sep 2016, at 21:57, Cameron Shorter
>>>>>>>     <mailto:cameron.shorter at gmail.com>> wrote:
>>>>>>>>     Hi Maria,
>>>>>>>>     What I've noticed as part of many OSGeo Committees is that
>>>>>>>>     after a while, some of the members become less active and
>>>>>>>>     less responsive, and that is ok.
>>>>>>>>     A typical person's engagement is a little like a bell
>>>>>>>>     curve. They start off being respectful and quite during a
>>>>>>>>     learning phase, then get engaged and productive, often
>>>>>>>>     solving a particular "itch", then involvement tapers off as
>>>>>>>>     the person's interest are reprioritised. When that person
>>>>>>>>     becomes less active, they typically have excellent advise
>>>>>>>>     based on experience, worth listening too. However, because
>>>>>>>>     the project is not the person's primary focus they are not
>>>>>>>>     monitoring or voting on day-to-day project activities.
>>>>>>>>     I'm suggesting our committee guidelines should allow for
>>>>>>>>     this engagement pattern, allowing old hands to provide
>>>>>>>>     advise when they have time and when practical.
>>>>>>>>     On 20/09/2016 6:36 AM, Maria Antonia Brovelli wrote:
>>>>>>>>>     Cameron, I understand your position. Anyway I think that
>>>>>>>>>     more people participating to a discussion and taking
>>>>>>>>>     decision is better than few. And, again, which is the
>>>>>>>>>     problem in voting? Once you read a motion, if it is a
>>>>>>>>>     simple one, it is easy to answer with 0 or +1 (it requires
>>>>>>>>>     just a couple of seconds). If there are doubts, better to
>>>>>>>>>     discuss it in such a way to find a larger consensus.
>>>>>>>>>     Sorry, but I really don't see the problem.
>>>>>>>>>     Cheers.
>>>>>>>>>     Maria
>>>>>>>>>     WorldWind Europa Challenge;SIFET
>>>>>>>>>     *SolKatzAward2015*
>>>>>     _______________________________________________
>>>>>     Conference_dev mailing list
>>>>>     Conference_dev at lists.osgeo.org
>>>>>     <mailto:Conference_dev at lists.osgeo.org>
>>>>>     http://lists.osgeo.org/mailman/listinfo/conference_dev
>>>>>     <http://lists.osgeo.org/mailman/listinfo/conference_dev>
>>>>     Cameron Shorter
>>>>     M +61 419 142 254
>>>>     _______________________________________________ Conference_dev
>>>>     mailing listConference_dev at lists.osgeo.org
>>>>     <mailto:Conference_dev at lists.osgeo.org>http://lists.osgeo.org/mailman/listinfo/conference_dev
>>>> -- Dr. Eng. Massimiliano Cannata Responsabile Area Geomatica
>>>> Istituto Scienze della Terra Scuola Universitaria Professionale
>>>> della Svizzera Italiana Via Trevano, c.p. 72 CH-6952
>>>> Canobbio-Lugano Tel: +41 (0)58 666 62 14 Fax +41 (0)58 666 62 09
>> Cameron Shorter
>> M +61 419 142 254
Cameron Shorter
M +61 419 142 254
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20160922/65af6d13/attachment-0001.html>
More information about the Conference_dev mailing list
