[OSGeo-Conf] Voting officer needed for FOSS4G 2018 selection
thomas bonfort thomas.bonfort at gmail.com
Wed Sep 28 00:21:29 PDT 2016
Hi Cameron,
I believe the integrity of the vote is guaranteed by the "secret"
token, as each voter can check his vote was accounted for correctly.
This manual process does not however guarantee anonymity as the CRO
has access to each voter's choice.
My experience being cro with limesurvey for osgeo-fr was rather
negative as I had to spend much more time dealing with the survey
itself than I would have to manually deal with the process (and IIRC
at the time anonymity was not guaranteed as the survey admin could
correlate votes with voters through the voting token).
Best regards,
Thomas
On 28 September 2016 at 08:56, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
> Hi Thomas,
> I suspect that Lime Survey provides the ability to guarantee the that the
> voting process hasn't been tampered with - ensuring that we can see who has
> voted, the results of the vote, but not how each person voted. (Jorge, can
> you please confirm this is the case).
> Such a voting system is preferable to having a person acting as a CRO, where
> the integrity of the CRO might be questioned. (Thomas, this is more of a
> protection of the CRO, rather than a question of the CRO's integrity).
> Warm regards, Cameron
> On 28/09/2016 7:51 AM, thomas bonfort wrote:
> Hi Jorge,
> Thanks for the offer.
> Given the number of voters from my point of view it seems easier to handle
> this manually than to setup and track a limesurvey. I'm fine to back off
> with my offer if the limesurvey proposal is preferred.
> Best regards,
> Thomas
> On Sep 27, 2016 11:35 PM, "Jorge Sanz" <jsanz at osgeo.org> wrote:
>> Hi Thomas,
>> At this very moment I'm happily working to set up the Board of
>> Directors voting on the LimeSurvey instance Geo-Spatial community set
>> up for OSGeo.
>> It's easy to use (and I can assist you) to give to the Conf Committee
>> a place to do the voting with reminders, tokens and everything, if you
>> think it's worth.
>> Best regards
>> On 27 September 2016 at 22:46, thomas bonfort <thomas.bonfort at gmail.com>
>> wrote:
>> > I can volunteer to be cro for the votes. I will be  more or less offline
>> > from Oct.24 to Nov.21 but that does not seem to interfere with the 2
>> > voting
>> > periods.
>> > With regards to accountancy, I propose that each voting member include a
>> > token known only to himself that will be published alongside the voting
>> > result, thus providing a way to be sure his/her vote was accounted for
>> > correctly.
>> > Regards,
>> > Thomas
>> > On Sep 27, 2016 9:18 PM, "Steven Feldman" <shfeldman at gmail.com> wrote:
>> >> Hi
>> >> We need someone who is not a member of the conference committee to act
>> >> as
>> >> Voting Officer for the 2 stages of voting to select the host for FOSS4G
>> >> 2018. Full details of dates and voting procedure at
>> >> https://wiki.osgeo.org/wiki/FOSS4G_2018_Bid_Process
>> >> Any offers?
>> >> Steven
>> >> _______________________________________________
>> >> Conference_dev mailing list
>> >> Conference_dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/conference_dev
>> Jorge Sanz
>> http://www.osgeo.org
>> http://wiki.osgeo.org/wiki/Jorge_Sanz
> Cameron Shorter
> M +61 419 142 254
More information about the Conference_dev mailing list
