[fdo-dev] FDO on Core 5: YES! (so far...)
Greg Boone greg.boone at autodesk.com
Fri Jul 14 09:06:10 EDT 2006
3.0.0 is compatible with the current MapGuide source code in Subversion. I see no reason why you should not be able to run your version of FDO with MapGuide.
Greg
-----Original Message-----
From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
Sent: Friday, July 14, 2006 3:01 AM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] FDO on Core 5: YES! (so far...)
Okay, looks like I got it to compile all the way through. Yay.  Thank
you all for your quick & valuable feedback.
Mateusz: You were right -- gcc 4.1.1 must be less forgiving when it
comes to redundant qualifications.  Perhaps there's a switch you can set
to disable it but in the meantime I just went ahead and deleted the
offending 'xxxxx::' qualification.
Carsten: You can get it to compile on FC5 if you systematically remove
the redundant declarations in the .h source files.  There are actually
several files for which you need to do this.  I should have written them
down but I was lazy and just re-ran "make" and waited for the next
error.  It always tells you what file and line number to fix.  Just keep
doing it (like, six times or so) and eventually it will compile.  Viel
Glück!
Greg: I know FDO 3.2 is not compatible with MapGuide, but what about
3.0?  Will it flat-out not work or can I try to compile the MapGuide
source code and see what happens?  In any case, I do hope the sync will
happen in the next few weeks like you said.
Thanks again,
-Marcus
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
