[fdo-internals] Running two different FDO Versions
geostarter martin.sagmeister at gmx.at
Mon Sep 15 07:27:15 EDT 2008
Hallo,
I work on a application which uses FDO 3.2 and want to include newer FDO 3.3
functionality! I can't remove the 3.2 version, because it's needed on a
legacy system. Can i run two FDO versions on the same process and how does
this work. I'm using the C# interface to access FDO 3.3.
Hope someone can help me
Kind regards
geostarter
View this message in context: http://www.nabble.com/Running-two-different-FDO-Versions-tp19491197p19491197.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
