[fdo-internals] Running two different FDO Versions
Jack Lee
jack.lee at autodesk.com
Mon Sep 15 07:35:05 EDT 2008
I am not sure what you are trying to do but FDO 3.2 and 3.3 are not binary compatible.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of geostarter
Sent: Monday, September 15, 2008 7:27 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Running two different FDO Versions
Hallo,
I work on a application which uses FDO 3.2 and want to include newer FDO 3.3
functionality! I can't remove the 3.2 version, because it's needed on a
legacy system. Can i run two FDO versions on the same process and how does
this work. I'm using the C# interface to access FDO 3.3.
Hope someone can help me
Kind regards
geostarter
View this message in context: http://www.nabble.com/Running-two-different-FDO-Versions-tp19491197p19491197.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
