[fdo-internals] Running two different FDO Versions
geostarter martin.sagmeister at gmx.at
Mon Sep 15 07:55:31 EDT 2008
I have an application which uses FDO 3.2 files and i want to extend it with a
component which needs FDO 3.3. Now i want to run both versions. When i run
the whole application the FDO 3.2 unmanated dll's are used because it's
loaded before, but i want to use FDO 3.3 in my component! So is it possible
to run both versions in one process?
Jack Lee-3 wrote:
> Hi,
> I am not sure what you are trying to do but FDO 3.2 and 3.3 are not binary
> compatible.
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of geostarter
> Sent: Monday, September 15, 2008 7:27 AM
> To: fdo-internals at lists.osgeo.org
> Subject: [fdo-internals] Running two different FDO Versions
> Hallo,
> I work on a application which uses FDO 3.2 and want to include newer FDO
> 3.3
> functionality! I can't remove the 3.2 version, because it's needed on a
> legacy system. Can i run two FDO versions on the same process and how does
> this work. I'm using the C# interface to access FDO 3.3.
> Hope someone can help me
> Kind regards
> geostarter
> http://www.nabble.com/Running-two-different-FDO-Versions-tp19491197p19491197.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/Running-two-different-FDO-Versions-tp19491197p19491525.html
More information about the fdo-internals mailing list
