[fdo-internals] PATCH: Fix for ticket #864 (and #889)
    Romica Dascalescu
    Romica.Dascalescu at autodesk.com
    Mon May 12 07:44:29 PDT 2014
Hi Jackie,
Code change looks OK.
Thanks,
Romica
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] on behalf of Jackie Ng [jumpinjackie at gmail.com]
Sent: Monday, May 12, 2014 10:37 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] PATCH: Fix for ticket #864 (and #889)
I've added a second version of the patch (864_sqlserver_v2.patch)
This should also fix ticket #889 as an analysis of the method shows that the
addLeftBr variable was never set to true before I submitted the initial
patch for review, meaning if the left operand contained a chain of OR
conditions and is part of a AND binary condition, it was never properly
parenthesised.
Since the area of code that affects #889 is the same area that affects #864,
I've rolled both fixes into the same patch.
Please review. Thanks
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/PATCH-Fix-for-ticket-864-tp5139747p5139787.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
