[fdo-users] #error : wchar_t must be defined
Traian Stanev
traian.stanev at autodesk.com
Sat Feb 14 13:30:59 EST 2009
It should work fine. I remember it used to compile with the "No" setting, a very long time ago.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Bob Cave
> Sent: Friday, February 13, 2009 2:12 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] #error : wchar_t must be defined
> I will be using FDO in our Windows software, which we build with "Treat
> wchar_t as Built-in Type"=No. Fdo.h generates an error when I use that
> option. Will I run into problems in FDO if I rebuild it without
> defining
> wchar_t as a built-in type?
> Thanks,
> Bob
> View this message in context: http://n2.nabble.com/-error-%3A--wchar_t-
> must-be-defined-tp2323123p2323123.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
