[fdo-users] Identity properties are not updateable ?!
bebeto
betak at softplan-slovakia.sk
Thu Oct 8 09:30:44 EDT 2009
I'm using OSGeo.SQLServerSpatial.3.4
I think when underlying datasource - sql server - support this, it should
work also with provider - without any limitations.
Orest Halustchak wrote:
> Hi,
> Which provider are you using? Some fdo providers don't allow the update of
> an identity property once it is set. You would have to delete the object
> and insert a new one with the new identity. Mostly this is an issue for
> providers that support things like long transaction tracking of changes to
> objects, history, etc. These rely on the identity of an object not
> changing.
> Thanks,
> Orest.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of bebeto
> Sent: Thursday, October 08, 2009 5:26 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Identity properties are not updateable ?!
> Hi,
> I have fdo schema where I have primary key (PK) editable (readonly=false).
> I'm able to INSERT any value when it is not NULL and unique (conditions
> for
> PK) . But I'm pretty surprised why I'm not able to UPDATE such property.
> I'm
> getting error:
> "Identity properties are not updateable"
> Any reason for this ? Is it a bug in FDO ?
> http://n2.nabble.com/Identity-properties-are-not-updateable-tp3786913p3786913.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Identity-properties-are-not-updateable-tp3786913p3788050.html
More information about the fdo-users
