[fdo-users] Connection problem SQL Server 2008 and FDO
psciga
scigalla at battefeld.com
Fri Oct 23 11:07:45 EDT 2009
Hi Lorenzo,
here the Layer definition:
#### begin ###
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
<VectorLayerDefinition>
<ResourceId>Library://sqlservertest2/db1.FeatureSource</ResourceId>
<FeatureName>dbo:geom</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<Filter />
<PropertyMapping>
<Name>id</Name>
<Value>id</Value>
</PropertyMapping>
<PropertyMapping>
<Name>name</Name>
<Value>name</Value>
</PropertyMapping>
<Geometry>graphik</Geometry>
<Url />
<ToolTip />
<VectorScaleRange>
<PointTypeStyle>
<DisplayAsText>false</DisplayAsText>
<AllowOverpost>false</AllowOverpost>
<PointRule>
<LegendLabel />
<Label>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>10</SizeX>
<SizeY>10</SizeY>
<Rotation>0</Rotation>
<MaintainAspect>true</MaintainAspect>
<Text>name</Text>
<FontName>Arial</FontName>
<ForegroundColor>000000</ForegroundColor>
<BackgroundColor>ffffff</BackgroundColor>
<BackgroundStyle>Transparent</BackgroundStyle>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<VerticalAlignment>'Baseline'</VerticalAlignment>
<Bold>false</Bold>
<Italic>false</Italic>
<Underlined>false</Underlined>
</Label>
<PointSymbolization2D>
<Mark>
<Unit>Points</Unit>
<SizeX>10</SizeX>
<SizeY>10</SizeY>
<InsertionPointX>0</InsertionPointX>
<InsertionPointY>0</InsertionPointY>
<Shape>Circle</Shape>
<Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>ff000000</ForegroundColor>
<BackgroundColor>ffffffff</BackgroundColor>
</Fill>
</Mark>
</PointSymbolization2D>
</PointRule>
</PointTypeStyle>
<LineTypeStyle>
<LineRule>
<LegendLabel />
<LineSymbolization2D>
<LineStyle>Solid</LineStyle>
<Thickness>1</Thickness>
<Color>000000</Color>
<Unit>Points</Unit>
</LineSymbolization2D>
</LineRule>
</LineTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
#### end ###
I'm only working with GEOMETRY type in MSSQL.
My table "geom" have 3 columns:
ID (primary key, autoincrment)
name (nchar)
graphik (geometry, with index)
Have you set a primary key column?
In the database I use mixed mode for login. From MG maestro I'm using
Specified credentials to make the connection to mssql server.
Sorry, I din't tell you, that I'm using MGOS 2.1 beta with PHP on XP.
With MGOS 2.0.2 (and the beta provider) I got an other problem: If there are
more the 7323 lines (I have only tested line objects) in the database, it
was impossible to make a selection. So I was trying 2.1.
LFELLI wrote:
> Hi Peter,
> thx for the tip, but unfortunatly doesn't solve my problem.
> My table is called "Streets" so i write
> <FeatureName>dbo:Streets</FeatureName>. I added the layer to the map but i
> still have no layer on the client side.
> Just for a test, in the map editor, i push the "Set view to current layers
> extent" using the Sql Server layer and i receive the following error
> message: "Failed to get layer extent: No spatial data found in layer"
> I notice that no Geometry is set in the XML, is this correct?
> May i ask you to post your layer configuration in XML?
> Opening the WebGis client, i'm able to see the other layer loaded with FDO
> SHP but no evidence for the sql one.
> No error reports on Error.log file.
> All my SHP layers has SRID 4326. I loaded the Streets layer in SqlServer
> using SqlSpatialTools from www.sharpgis.net using SRID 4326.
> Lorenzo
View this message in context: http://n2.nabble.com/Connection-problem-SQL-Server-2008-and-FDO-tp3764539p3879275.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
