[fdo-users] Connection problem SQL Server 2008 and FDO
LFELLI
lofelli at tiscali.it
Wed Oct 28 10:02:04 EDT 2009
Hi Peter,
thank you very much man! Now i can see the layer.
I've the selection problem too with only 891 record so i think it should
depend by some other factors (number of columns and number of record...)
i'll try the beta of MGOS.
Anyway... THX!
psciga wrote:
> Hi Lorenzo,
> here the Layer definition:
> #### begin ###
> <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
> <VectorLayerDefinition>
> <ResourceId>Library://sqlservertest2/db1.FeatureSource</ResourceId>
> <FeatureName>dbo:geom</FeatureName>
> <FeatureNameType>FeatureClass</FeatureNameType>
> <Filter />
> <PropertyMapping>
> <Name>id</Name>
> <Value>id</Value>
> </PropertyMapping>
> <PropertyMapping>
> <Name>name</Name>
> <Value>name</Value>
> </PropertyMapping>
> <Geometry>graphik</Geometry>
> <Url />
> <ToolTip />
> <VectorScaleRange>
> <PointTypeStyle>
> <DisplayAsText>false</DisplayAsText>
> <AllowOverpost>false</AllowOverpost>
> <PointRule>
> <LegendLabel />
> <Label>
> <Unit>Points</Unit>
> <SizeContext>DeviceUnits</SizeContext>
> <SizeX>10</SizeX>
> <SizeY>10</SizeY>
> <Rotation>0</Rotation>
> <MaintainAspect>true</MaintainAspect>
> <Text>name</Text>
> <FontName>Arial</FontName>
> <ForegroundColor>000000</ForegroundColor>
> <BackgroundColor>ffffff</BackgroundColor>
> <BackgroundStyle>Transparent</BackgroundStyle>
> <HorizontalAlignment>'Center'</HorizontalAlignment>
> <VerticalAlignment>'Baseline'</VerticalAlignment>
> <Bold>false</Bold>
> <Italic>false</Italic>
> <Underlined>false</Underlined>
> </Label>
> <PointSymbolization2D>
> <Mark>
> <Unit>Points</Unit>
> <SizeX>10</SizeX>
> <SizeY>10</SizeY>
> <InsertionPointX>0</InsertionPointX>
> <InsertionPointY>0</InsertionPointY>
> <Shape>Circle</Shape>
> <Fill>
> <FillPattern>Solid</FillPattern>
> <ForegroundColor>ff000000</ForegroundColor>
> <BackgroundColor>ffffffff</BackgroundColor>
> </Fill>
> </Mark>
> </PointSymbolization2D>
> </PointRule>
> </PointTypeStyle>
> <LineTypeStyle>
> <LineRule>
> <LegendLabel />
> <LineSymbolization2D>
> <LineStyle>Solid</LineStyle>
> <Thickness>1</Thickness>
> <Color>000000</Color>
> <Unit>Points</Unit>
> </LineSymbolization2D>
> </LineRule>
> </LineTypeStyle>
> </VectorScaleRange>
> </VectorLayerDefinition>
> </LayerDefinition>
> #### end ###
> I'm only working with GEOMETRY type in MSSQL.
> My table "geom" have 3 columns:
> ID (primary key, autoincrment)
> name (nchar)
> graphik (geometry, with index)
> Have you set a primary key column?
> In the database I use mixed mode for login. From MG maestro I'm using
> Specified credentials to make the connection to mssql server.
> Sorry, I din't tell you, that I'm using MGOS 2.1 beta with PHP on XP.
> With MGOS 2.0.2 (and the beta provider) I got an other problem: If there
> are more the 7323 lines (I have only tested line objects) in the database,
> it was impossible to make a selection. So I was trying 2.1.
> LFELLI wrote:
>> Hi Peter,
>> thx for the tip, but unfortunatly doesn't solve my problem.
>> My table is called "Streets" so i write
>> <FeatureName>dbo:Streets</FeatureName>. I added the layer to the map but
>> i still have no layer on the client side.
>> Just for a test, in the map editor, i push the "Set view to current
>> layers extent" using the Sql Server layer and i receive the following
>> error message: "Failed to get layer extent: No spatial data found in
>> layer"
>> I notice that no Geometry is set in the XML, is this correct?
>> May i ask you to post your layer configuration in XML?
>> Opening the WebGis client, i'm able to see the other layer loaded with
>> FDO SHP but no evidence for the sql one.
>> No error reports on Error.log file.
>> All my SHP layers has SRID 4326. I loaded the Streets layer in SqlServer
>> using SqlSpatialTools from www.sharpgis.net using SRID 4326.
>> Lorenzo
View this message in context: http://n2.nabble.com/Connection-problem-SQL-Server-2008-and-FDO-tp3764539p3905682.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
