[fdo-users] Fgf to Wkb
Traian Stanev traian.stanev at autodesk.com
Mon Dec 20 15:26:14 EST 2010
You can try the method used by the OGR provider. See OgrFdoUtil.cpp, function Fgf2Wkb. Similar method is used in the SQLite provider (SltGeomUtils.cpp, function Fgf2Wkb).
The downside is, you would have to port it to C#, since it's written in C++. The upside is that it is likely the fastest method.
Traian
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of maland
Sent: Monday, December 20, 2010 9:22 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Fgf to Wkb
Hello,
What is the correct/fastest way to convert from Fgf to Wkb?
I am using the FDO from .Net.
Currently I'm doing it this way:
byte[] fgfBytes = reader.GetGeometry(p.Name);
using (FgfGeometryFactory gf = new FgfGeometryFactory())
  using(IGeometry geom = gf.CreateGeometryFromFgf(fgfBytes))
    byte[] wkbBytes = gf.GetWkb(geom);
    // Do some stuff with the WKB array
For some rather large MultiLineString geometries this takes incredibly long
time, specially the GetWkb function. E.g. one geometry concisting of 1500 kB
data takes about 10 seconds. (I have a rather fast computer...)
Is this the correct way to create a Wkb from Fgf?
Regards
Henning Maeland
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fgf-to-Wkb-tp5850828p5850828.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
