[fdo-users] FGF and ISO SQL/MM WKB
Oyvind Idland
oyvind.idland at gmail.com
Tue Sep 21 08:55:02 EDT 2010
Hi Orest,
thanks for your info.
We are currently developing a system at my place, where we use the SQL/MM
WKB as the internal
geometry protocol.
Oracle SDO do have support for SQL/MM WKB/WKT (and also has adopted other
parts of the standard),
at least from version 11g.
I think there are some work done in PostGIS aswell.
A WKB-talking FDO would be perfect in our situation :)
-- Øyvind
On Tue, Sep 21, 2010 at 2:15 PM, Orest Halustchak <
orest.halustchak at autodesk.com> wrote:
> Hi Øyvind,
> There are no plans right now, but it would be good to support that
> extension as it is an OGC extension as well. OGC hadn’t defined it yet when
> the FGF spec was done, which is why they’re not exactly the same. The topic
> came up a while ago as part of a futures discussion, see
> http://trac.osgeo.org/fdo/wiki/FdoOGCSFSGeometry, but we didn’t follow up.
> If we added support, we would have to be backwards compatible with all the
> existing FGF-based geometry data. But, moving forward to support the OGC
> extensions would allow us to be compatible with products that are generating
> data using the new OGC WKB format.
> Do you or others see other products starting to make heavy use of the new
> version of WKB or WKT?
> Thanks,
> Orest.
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Oyvind Idland
> *Sent:* Tuesday, September 21, 2010 3:38 AM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] FGF and ISO SQL/MM WKB
> Is there any plans to adopt the WKB extension in ISO SQL/MM into FDO ?
> This version of WKB/WKT solves most of what FGF tries to do, such as Z / M
> ordinates and circular geometries.
> As of the one byte misalignment, this can be worked around by padding
> bytes.
> regards,
> Øyvind Idland
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100921/499e7efc/attachment.html
More information about the fdo-users
