[fdo-users] Re: SDE and slow multi-geometries
Oyvind Idland oyvind.idland at gmail.com
Wed Jun 22 04:09:28 EDT 2011
Hello,
I just submitted a patch, see Ticket #735. Sorry for taking to long time !
The patch was created from 3.5.0, so it should be merged into newer
versions.
As mentioned in a different thread, some of the unit-tests crashes (not
related to this patch) and problems related to this should probably be fixed
by somebody.
The new code is affected by the tests that works, and has been running in
our production environment for a while without problems.
-- Oyvind
On Tue, Feb 22, 2011 at 4:36 PM, Greg Boone <greg.boone at autodesk.com> wrote:
>  >> I assume there are tests that validates geometries****
> I would not assume this. You may want to take a look and see if those tests
> exist.****
> Greg****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Oyvind Idland
> *Sent:* Saturday, February 19, 2011 9:02 AM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] Re: SDE and slow multi-geometries****
> Hello Dan and Greg,
> we are currently using 3.5, and we are in the middle of a release. I could
> patch 3.5 locally and use
> our own binaries.
> I'll try to run the test suite during beginning of the week, and check if
> the tests triggers new code. I assume
> there are tests that validates geometries. I can add necessary test code if
> I find that something is left out.
> After testing I can attach the patch.
> PS the memory leak I mentioned was fixed in a different way than I
> described.
> -- Oyvind
> On Fri, Feb 18, 2011 at 5:23 PM, Dan Stoica <dan.stoica at autodesk.com>
> wrote:****
> Hi Oyvind,****
> In addition, before submitting the patch please run the unit tests suite.*
> Does your change needs a specific unit test thus making sure it is
> exercised?****
> Dan.****
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Greg Boone
> *Sent:* Friday, February 18, 2011 10:19 AM****
> *To:* FDO Users Mail List****
> *Subject:* RE: [fdo-users] Re: SDE and slow multi-geometries****
> Can you create an svn patch and attach it to the ticket related to this
> defect? Once that is done I can have a few people look at the changes and
> have it submitted. ****
> At this point these changes can go into the trunk, and possibly the 3.6
> branch. Is there a requirement to have the changes ported back to 3.5?****
> Greg****
> *Sent:* Friday, February 18, 2011 5:05 AM
> *Subject:* [fdo-users] Re: SDE and slow multi-geometries****
> The code is now fixed. As I got started, I also did some related code
> cleanup:
> - the macro function EXPAND() are now gone. Instead, I made a simple
> templated
> array class with an array subscript operator. This looks much cleaner now
> and can be
> debugged.
> - the macro function ADD_POINT is also gone, replaced with an inline static
> function.
> - memory leak: ArcSDEConnection, line 885:
> CHAR *qualified_table_name = new CHAR[SE_QUALIFIED_TABLE_NAME+1];
> This one never gets deleted. I can't see any reason to use new, so I
> replaced it
> with an array instead:
> CHAR qualified_table_name [SE_QUALIFIED_TABLE_NAME+1];
> However, there are still things I'd like to do with the code: The geometry
> buffering is
> attached to the ArcSDEConnection class, and functions like
> convert_sde_shape_to_fgf()
> are poking around in these arrays (XY, Z, parts etc). What I would like to
> do, is to
> wrap all these arrays together with the indexing code into a new SDE
> geometry
> handling class. This won't add anything new, just make it more clean.
> Where can I submit/send the changes ?
> -- Oyvind
> On Wed, Feb 16, 2011 at 4:53 PM, Oyvind Idland <oyvind.idland at gmail.com>
> wrote:****
> Hello,
> I have been looking into an issue that was brought up here earlier. Turns
> out that the SDE API
> is slower than cold molassis when using SE_shape_get_num_points() on
> multipart geometries.
> I did some experimentation using the index tables returned from
> SE_shape_get_all_points()
> directly. The total processing speed on my dataset went from roughly 20
> secs down to less than
> 1 sec. There are several huge polygons with 200+ holes in them, and
> multilines.
> Why the native SDE API is so slow is a mystery, those indices should not
> require heavy
> calculation.
> The code is experimental so far, but when I finish writing the code, I can
> submit a patch
> if desired.
> -- Øyvind Idland ****
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users****
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110622/3f361562/attachment.html
More information about the fdo-users mailing list
