[FOSS-GPS] Openmoko Freerunner compatible GPS software
Fabrizio Giudici
fabrizio.giudici at tidalwave.it
Tue Sep 23 03:13:15 EDT 2008
Can you try windRose? Official testing so far is only on PalmOS, but I
know some people has run it over other MIDP phones. If it need fixes for
windRose, I'd made it happily.
Cheers.
Risto H. Kurppa wrote:
> I have an Openmoko Freerunner phone and I like it a lot. I know that
> there are around 10 other Freerunner owners so I thought I'd post some
> comments.
> OK, Freerunner has some glitches (like I don't feel comfortable using
> it as my daily phone because of the bad battery duration and audio
> quality, both fixable with software) but it has GPS, accelerometers,
> GPRS, WLAN and Linux so I'm pretty happy and waiting for the software
> to become more usable. Since this is my first GPS device I'm kind of
> interested in the GPS tools and applications and here's a short review
> of some tools I've tried.
> Gpssight
> http://projects.openmoko.org/projects/gpv
> http://wiki.openmoko.org/wiki/GPS_Sight
> GOOD
> * Is able to sync Freerunner clock (though I don't think I've
> managed to make it work ever..)
> BAD
> * small buttons of UI
> * no satellite signal strength information
> Agpsui
> http://wiki.openmoko.org/wiki/Howto_Test_Your_GPS_with_agpsui
> GOOD
> * Shows a lot of information about the connection: map, individual
> satellite signal strengths, position plot, signal log etc
> * helps to test different restarts (cold/warm/hot)
> BAD
> * after first fix pretty useless to a normal user
> * bad UI, small buttons
> TangoGPS
> http://www.tangogps.org
> http://wiki.openmoko.org/wiki/TangoGPS
> GOOD
> * most comprehensive
> * saves tracks (that need to be converted to .gpx before they can
> be used) to upload to Openstreetmap or other tools
> * uses Openstreetmap as well as other map sources
> * is able to show geotagged photos (haven't tried)
> * can save and load POC:s and show friends (though I have no idea
> how it works and where the data is stored and so on)
> BAD
> * Nothing really bad but there are some features missing to make
> it really smooth & usable. See my wishes below.
> WISHLIST
> * zoom to show 1 pix as 4pix or so (the high dpi of Freerunner
> isn't always good, if the device is not so close to your eyes)
> * Show better information about the satellites - signal strength
> for each satellite would be nice.
> * GPX data format for better compability
> * Ability to show GPX tracks (ie. create a track on the desktop,
> upload to phone and follow the track to get to places)
> * multiple waypoints for more complex navigation
> * default location where to go if no GPS signal available
> * possibility to give a custom text to catenate in the saved gps
> track filename
> As you see TangoGPS get's most of my attention as the best and most
> usable tool there is available at the moment.. Feel free to implement
> my wishes :)
> Orrery
> http://projects.openmoko.org/projects/orrery/
> http://wiki.openmoko.org/wiki/Orrery
> GOOD
> * Shows the stars and the constellations on the sky
> * Fast development - a new release just out again!
> BAD
> Haven't used enough and don't know enough about stars to estimate it's
> usefulness but it's a nice tool anyway :)
> Other software
> I haven't tried the locations tool of 2008.8 or 2008.9. I also know
> that gpsd is running somewhere down there but I have no opinion about
> it. If it works, its good :)
> At Openmoko Projects page
> (http://projects.openmoko.org/softwaremap/trove_list.php?form_cat=308)
> you can find more GPS software. I'll propably have to try some of
> those as they get more mature or so. I should also learn to use
> navigation software like Navit.
> r
> Since this become that good post (my opinion :) I'll post it on my
> blog as well: http://risto.kurppa.fi/blog/freerunner-compatible-gps-software/
Fabrizio Giudici, Ph.D. - Java Architect, Project Manager
Tidalwave s.a.s. - "We make Java work. Everywhere."
weblogs.java.net/blog/fabriziogiudici - www.tidalwave.it/blog
Fabrizio.Giudici at tidalwave.it - mobile: +39 348.150.6941
More information about the FOSS-GPS
