[FOSS-GPS] FoxtrotGPS OsmGpsMap integration (was: FoxtrotGPS
paint-optimize branch)
John Stowers
john.stowers.lists at gmail.com
Wed May 19 01:08:20 EDT 2010
On Wed, May 19, 2010 at 3:56 AM, Sander van Grieken <sander at 3v8.net> wrote:
> On Tuesday 18 May 2010 11:20:05 John Stowers wrote:
> > Some work is ongoing here, API comments welcomed.
> > http://github.com/nzjrs/osm-gps-map/tree/track-api-rework
> Ah you have created add/remove track functions, nice. I found that by using
> the _replace
> function I can simulate add/remove, but I will switch over to the new
> functions once
> there's a new release of OGM.
Yeah, the new API should be a little more consistent.
* The map has an internal 'GPS track' (an OsmGpsMapTrack object). The
_gps_add function/s operate on this track so that the library retains a
simple API if you only want to draw one track
* If you want to have multiple tracks then the new API will be something
like
OsmGpsMapTrack *t;
t = osm_gps_map_track_new()
osm_gps_map_track_set_color(something)
osm_gps_map_add_track(map, track)
void got_gps_data(float lat, float lon) {
OsmGpsMapPoint p;
osm_gps_map_point_from_degrees(&p, lat, lon)
osm_gps_map_track_add_point(t, &p)
i.e. all track interaction can be done through the track object, and you
don't need to call functions on the map object.
> I just hooked up the OsmGpsMap defined maps into foxtrotGPS and I noticed
> that setting the
> map-source property does not redraw the map. It will use the new source
> though when
> forcing a redraw by using zoom in or out.
This is a bug.
John
> grtz,
> Sander
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/fe342684/attachment.html
More information about the FOSS-GPS
