[FOSS-GPS] FoxtrotGPS OsmGpsMap integration (was: FoxtrotGPS
paint-optimize branch)
John Stowers
john.stowers.lists at gmail.com
Mon May 24 07:53:19 EDT 2010
On Tue, 2010-05-18 at 17:56 +0200, Sander van Grieken wrote:
> On Tuesday 18 May 2010 11:20:05 John Stowers wrote:
> > Some work is ongoing here, API comments welcomed.
> > http://github.com/nzjrs/osm-gps-map/tree/track-api-rework
> Ah you have created add/remove track functions, nice. I found that by using the _replace
> function I can simulate add/remove, but I will switch over to the new functions once
> there's a new release of OGM.
> I just hooked up the OsmGpsMap defined maps into foxtrotGPS and I noticed that setting the
> map-source property does not redraw the map. It will use the new source though when
> forcing a redraw by using zoom in or out.
This has been fixed in git HEAD. You could also call
osm_gps_map_scroll(0,0).
John
> grtz,
> Sander
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
