[FOSS-GPS] introduction and first help request
Mauro Ugarte A
mauro.ugarte at cefop.udec.cl
Thu May 27 02:12:37 EDT 2010
Hi John,
We are just starting on this, your project seems very advanced. Thanks
for sharing your setup info, i hadn't heard about RouterstationPRO, we
are still looking for the right single board PC and this one may be "the
one". We where thinking about RF transceivers to deliver the RTCM
messages, because we need to reach the rovers farther than 2 Km in a
zone not covered by GPRS nor WIFI nor WIMAX nor even wired internet.
When do you think the "work in progress" SW should be ready to "peek" on
Best regards,
Mauro U.
> I'm also in the process of setting up a low cost base station.
> The components I'm using:
> o Magellan AC12 gps card (~$160)
> o Ubuiquiti routerstation pro, single board computer (~$90)
> o FTDI USB-TTL converter cable (~$20)
> o Misc connectors, breadboard (~$25)
> o Weathertight box, pipe fittings for antenna mount (~$30)
> o Trimble compact dome antenna, ebay ($75)
> The AC12 is a single frequency OEM card which has been around for a few
> years. It is a 1 HZ unit, but it provides excellent phase measurements (even
> better than the LEA-4T). It requires a small amount of breadboarding to
> hook up, but it is mainly a matter of matching the wires from the USB-TTL
> cable to the ribbon cable from the AC12.
> The "work in progress" software generates RTCM 3.1 records and distributes
> them through a lightweight NTRIP caster, all of which run on the single
> board computer. The Routerstation PRO is designed to be wifi router, but it
> has more than enough capacity.
> The entire station fits in a weathertight box; both data and power are
> provided over a single Ethernet cable.
> -----Original Message-----
> From: foss-gps-bounces at lists.osgeo.org
> [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of Eugenio Realini
> Sent: Wednesday, May 26, 2010 7:47 PM
> To: Open Source GPS-related discussion and support
> Subject: Re: [FOSS-GPS] introduction and first help request
> Hi Mauro,
> 2010/5/27 Mauro Ugarte A<mauro.ugarte at cefop.udec.cl>:
>> 1- First of all, in Chile there is nothing like a GPS reference
>> station network providing corrections on NRTK/NTRIP, which we could
>> rely on. There is an IGS station, though. It is near our lab (about 3
>> km), codenamed CONZ and labeled "highrate_permanent" under GNSS/files
>>> Data Archive> File Browser at GNSS Data Center website
>> (http://igs.bkg.bund.de/index/index) and provides RINEX files that
>> should help at post-processing but not for real time aplications (please
> correct me if i'm wrong).
> I checked here http://www.igs-ip.net/home and it seems that CONZ station
> data can be accessed via NTRIP:
> IP: www.igs-ip.net
> Port: 2101
> User& pass: you have to register here
> http://igs.bkg.bund.de/ntrip/registeruser
> This is the source table line for CONZ:
> STR;CONZ0;Concepcion-TIGO;RTCM
> 3.0;1004(1),1006(15),1008(15),1012(1),1019,1020,1033(15);2;GPS+GLO;IGS;CHL;-
> 36.84;286.98;0;0;LEICA
> GRX1200GGPRO;none;B;N;3600;BKG
> It already has all the messages you could want, and if it is not located
> where you need it to be, at least you can use it for some initial testing!
>> 1- Should we buy a RTK capable reference station module, that outputs
>> RTCM-RTK messages to use them as an input to rtklib/gogps? (example:
>> magellan DG-14), or could we use another low cost module that outputs
>> raw data measurements and "convert" that raw data into the
>> corresponding RTCM-RTK messages to feed rtklib/gogps?. I ask this
>> because it seems to me that RTCM V3.1 messages broadcasted by RTK
>> reference stations (1001-1002 for precision GPS L1 only, 1003-1004 for
>> precision GPS L1& L2) could be "constructed" by raw data output, and
>> messages 1005-1006 too, using the station position. Is all this possible
> or am i missing something?
> That is right, you can do it either ways: buy a module with RTCM output or
> construct RTCM once you got raw data. Obviously the second option requires
> much more work and trial&error.
>> 2- Do you know alternatives to LEA-4T, at low cost, that seems to you
>> that should stay around at least a couple of years and output raw data
>> which we can feed (or convert to feed) to rtklib/gogps?. We know that
>> there are the u-blox LEA-5T and LEA-6T, but those output raw data at 2
>> Hz and 5 Hz respectively, and the last one is just born so firmware
>> bugs could happen as they happened to LEA-5T, so if you know another
>> faster and cheaper, please let me know.
> Do you really need 10Hz for pedestrian rovers? If you mean for broadcasting
> RTCM, permanent stations I know about broadcast at 1 Hz.
> As for firmware bugs, they can happen with everything... let's hope u-blox
> people learned from 5T mistakes and that 6T will be better ;)
> Interesting project, anyway! Please keep us updated.
> Eugenio
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
More information about the FOSS-GPS
