[FOSS-GPS] Dead Reckoning?
Tomoji TAKASU ttaka at yk.rim.or.jp
Sat Jul 9 03:50:09 EDT 2011
Dear Danny
> How much potential is there to improve position with Kalman filtering in
> RTKLib?
RTKLIB already uses Kalman filter and you can enable DR with
Options - Rec-Dynamics ON. (It can be enabled only in relative
modes)
As to INS-integration, the performance much depends on the
IMU grade. At least FOG or RLG-class is needed to improve RTK
solutions. Low-cost MEMS is only effective to compensate very
short outage of GPS data. Refer my ION paper too.
http://gpspp.sakura.ne.jp/paper2005/ion2008_paper_ttaka.pdf
> How heavily does RTKLib filter the solution with its history of past
> solutions and estimated velocity?  Or does it largely rely on the current
> solution without filtering a history of past positions and velocity
> estimates?
With Rec-Dynamics ON, it depends on the process noise
parameters of receiver acceleration. If the value larger, the weight
of past estimated velocity decreases.
regards,
Tomoji TAKASU
Sent: Saturday, July 09, 2011 4:05 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Dead Reckoning?
> RTKLib?
> I have an Inertial Measurement Unit on the rover with accelerometers and a
> magnetometer compass, and there's tachometers on the wheels.  The rover
> will not move quickly, but compass headings are never exact, and
> tachometer counts will have some slippage on rough ground.  Basically it
> is a fair Dead Reckoning input, but with all the usual problems of DR.
> estimates?
> I saw there is a parameter for a limit on acceleration.  Would a parameter
> limited velocity helpful?  The rover's speed is limited, although it can
> stop immediately upon obstacles.  Of course, with a DR input stream, the
> limits on velocity and acceleration could be versus the DR-estimated
> position, so they could be a much lower correction for drift once the
> starting location is resolved.
> Danny
> On 6/20/2011 7:34 PM, Tomoji Takasu wrote:
>> Dear Danny
>>> I don't see any way this could be provided as a type of correction
>>> information.  Is it possible?
>> Basically all is possible because all of the source codes
>> are open.
>> However, I recommend loosely-coupled integration
>> implemented outside of RTKLIB.
>> For tightly-coupled integration, you have to modify the
>> filter code deeply. It mignt be hard way.
>> regards,
>> Tomoji TAKASU
>> From: "Danny Miller" <dannym at austin.rr.com>
>> Sent: Tuesday, June 21, 2011 8:45 AM
>> Subject: [FOSS-GPS] Dead Reckoning?
>>> I plan on making a rover with an IMU containing XYZ linear
>>> accelerometers, rotational accelerometers, and 3D magnetometer compass.
>>> There will also be tachometers on the wheels.
>>> This serves to orient the rover with a compass heading, and detect
>>> collisions or loss of traction.  It may also help in short-term
>>> navigation should the RTKlib lose carrier lock.
>>> Could this information be integrated as correction information for
>>> RTKlib? The IMU has inherent offset errors and is not accurate over
>>> significant time periods, and tachometers are inaccurate on rough ground
>>> since tires slip.  It can, however, provide guidance for RTK solutions
>>> when the solution is in doubt.  Going from a Fixed solution to a float
>>> that jumps over 2M, the IMU's evidence that no such motion occurred
>>> should be a useful correction.  Now given 30 sec of motion, assuming
>>> it's been moving, the IMU's range of error is such that the IMU vector
>>> from the last known Fixed time could be several meters.   Even still, I
>>> would expect that having information on how the rover is moving would
>>> improve the ability to resolve to an accurate solution.
>>> Thanks,
>>> Danny
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
More information about the FOSS-GPS mailing list
