[FOSS-GPS] Can't get Ambiguity Validation Ratio to move
Tomoji Takasu
ttaka at yk.rim.or.jp
Mon Jun 20 17:11:06 EDT 2011
Dear Danny
> How does it calculate E/N/U-Baseline without a base location? The spatial
> orientation of the EN plane changes (rotates) with lat/long.
> I assume it calculates an approximate lat/long solution and uses that to
> come up with the orientation of the ENU coordinate system? Can it do this
> with SkyTraq-Raw, without a solution from the receiver itself?
The base-station position is fixed to just the single-solution
of the base-station. It does not need receiver's NMEA.
About 10 m error of the base-station position does not
affect the relative solution.
Tomoji TAKASU
Sent: Tuesday, June 21, 2011 5:16 AM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Can't get Ambiguity Validation Ratio to move
> OK, I was wondering about that. The base is not actually moving, but this
> seems right.
> BTW, I am very excited about RTKlib, and cannot thank you enough for
> making it available the way you have. There is no shortage of practical
> uses for this.
> Thanks,
> Danny
> On 6/20/2011 2:40 PM, Tomoji Takasu wrote:
>> Dear Danny
>>> What is the best way to determine a location? If I use a single unit's
>>> NMEA, I will not know the location with centimeter accuracy.
>> Collect receiver data in some period, process them in
>> "Single" mode and average the results.
>>> Am I correct in understanding that the small error in base location will
>>> not affect the relative accuracy of the base-to-rover difference? Only
>>> that the absolute location of the rover will be off by an identical
>>> amount?
>> You are right.
>>> It might be useful to have a mode where the output is purely a relative
>>> distance vector might be useful. Would that get rid of the need to fix
>>> exact coordinates for a base?
>> Use "Moving-Base" mode and output "E/N/U-Baseline".
>> regards,
>> Tomoji TAKASU
>> From: "Danny Miller" <dannym at austin.rr.com>
>> Sent: Tuesday, June 21, 2011 1:34 AM
>>> OK- thank you so much! I will try it out!
>>> amount?
>>> I was gonna say "maybe it should get an inaccurate base location from
>>> NMEA", but SkyTrak-Raw doesn't offer a calculated position fix at all.
>>> Danny
>>> On 6/20/2011 3:56 AM, Tomoji Takasu wrote:
>>>> Dear Danny
>>>>> In the data window of RTKNavi, I noticed the Lat/long/height of Base
>>>>> is not listed with real numbers (90deg 0m). This isn't right- that
>>>>> GPS has a fine solution in NMEA.
>>>> You have to set the base-station position properly in
>>>> Options dialog for relative modes. RTKNAVI never uses
>>>> receiver's NMEA.
>>>> This is FAQ. So I will add FAQ in the support page.
>>>> regards,
>>>> Tomoji TAKASU
>>>> Sent: Monday, June 20, 2011 5:07 PM
>>>> To: <foss-gps at lists.osgeo.org>
>>>> Subject: [FOSS-GPS] Can't get Ambiguity Validation Ratio to move
>>>>> I'm new to RTK. I have a pair of LEA-6T GPS units, one active
>>>>> Sarantel SL-1206 quadrafiliar helix ant. There were supposed to be
>>>>> two of those but the second one was DOA so I'm making do with an
>>>>> active patch antenna for the second. I don't have an antenna file for
>>>>> either of them. I'm using 2.4.1.
>>>>> I have UBX RXM-RAW and RXM-SFRB reading out of both of them at 5Hz
>>>>> (tried this at 1Hz too). I can get a fix out of either one of them.
>>>>> In Kinematic mode of RTKNavi, I get a position, but the "ratio factor
>>>>> of ambiguity validation" factor is stuck at 0.0. I waited like an
>>>>> hour and it was still at 0.
>>>>> GPS has a fine solution in NMEA. Both Base and Rover are showing
>>>>> strong (~45dbHz) signal bars in all colors.
>>>>> I looked under Solution 1 and Solution 2 and both have valid, similar
>>>>> solutions.
>>>>> I looked under errors and saw:
>>>>> eight "outlier rejected" per sample period (5Hz)
>>>>> one "no double-differenced residuals" message
>>>>> I tried switching the COM ports for Base and Rover, effectively
>>>>> switching which unit was which (neither is moving right now). Nothing
>>>>> changed, the "Base" unit channel still has no Lat/long/height and
>>>>> ambiguity validation is still 0. That is, the problem is not tied to
>>>>> the GPS hardware unit.
>>>>> I tried disabling the Rover in RTKnavi. There's still no solution
>>>>> under the Lat/Long/Height of Base. The signal strength bars all turn
>>>>> gray.
>>>>> I tried the mkl version (I have an i7). It didn't change anything.
>>>>> I tried 2.4.0 rtknavi. In that one, I can't get a rover solution to
>>>>> show up at all, it's blank on the main window and rtkplot shows
>>>>> nothing.
>>>>> Any ideas?
>>>>> Danny
>>>>> _______________________________________________
>>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>>> list.
>>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>>>> subscription
>>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>>> subscription
>>> subscription
>> subscription
> subscription
More information about the FOSS-GPS
