[FOSS-GPS] Dead Reckoning?
Danny Miller
dannym at austin.rr.com
Mon Jun 20 19:45:43 EDT 2011
I plan on making a rover with an IMU containing XYZ linear
accelerometers, rotational accelerometers, and 3D magnetometer compass.
There will also be tachometers on the wheels.
This serves to orient the rover with a compass heading, and detect
collisions or loss of traction. It may also help in short-term
navigation should the RTKlib lose carrier lock.
Could this information be integrated as correction information for
RTKlib? The IMU has inherent offset errors and is not accurate over
significant time periods, and tachometers are inaccurate on rough ground
since tires slip. It can, however, provide guidance for RTK solutions
when the solution is in doubt. Going from a Fixed solution to a float
that jumps over 2M, the IMU's evidence that no such motion occurred
should be a useful correction. Now given 30 sec of motion, assuming
it's been moving, the IMU's range of error is such that the IMU vector
from the last known Fixed time could be several meters. Even still, I
would expect that having information on how the rover is moving would
improve the ability to resolve to an accurate solution.
I don't see any way this could be provided as a type of correction
information. Is it possible?
Thanks,
Danny
More information about the FOSS-GPS
