[FOSS-GPS] Dead Reckoning?
Tomoji Takasu
ttaka at yk.rim.or.jp
Mon Jun 20 20:34:48 EDT 2011
Dear Danny
> I don't see any way this could be provided as a type of correction
> information. Is it possible?
Basically all is possible because all of the source codes
are open.
However, I recommend loosely-coupled integration
implemented outside of RTKLIB.
For tightly-coupled integration, you have to modify the
filter code deeply. It mignt be hard way.
regards,
Tomoji TAKASU
Sent: Tuesday, June 21, 2011 8:45 AM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] Dead Reckoning?
> I plan on making a rover with an IMU containing XYZ linear accelerometers,
> rotational accelerometers, and 3D magnetometer compass.
> There will also be tachometers on the wheels.
> This serves to orient the rover with a compass heading, and detect
> collisions or loss of traction. It may also help in short-term navigation
> should the RTKlib lose carrier lock.
> Could this information be integrated as correction information for RTKlib?
> The IMU has inherent offset errors and is not accurate over significant
> time periods, and tachometers are inaccurate on rough ground since tires
> slip. It can, however, provide guidance for RTK solutions when the
> solution is in doubt. Going from a Fixed solution to a float that jumps
> over 2M, the IMU's evidence that no such motion occurred should be a
> useful correction. Now given 30 sec of motion, assuming it's been moving,
> the IMU's range of error is such that the IMU vector from the last known
> Fixed time could be several meters. Even still, I would expect that
> having information on how the rover is moving would improve the ability to
> resolve to an accurate solution.
> Thanks,
> Danny
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
