[FOSS-GPS] Post-processing RINEX to simulate RTK
julio menezes
yjmenezes at yahoo.com.br
Mon Oct 24 15:18:18 EDT 2011
Dear Antonio,
I'm not an expert too. I am working on the same direction as you.
If you have logged RTCM to, I think RTKLIB can be used, there is an stream server that take receiver data from files.
- STRSVR, STR2STR: communication utility.
Take a look on:
http://www.rtklib.com/ Tutorial and Demonstration 2011/06/12 new.
Or you can post-process as kinematic and use the processed output, but it will not be real-time as you want.
good luck !
julio menezes
GNU/Linux user, from BraSil.
--- Em seg, 24/10/11, António Pestana <afsm.pestana at gmail.com> escreveu:
De: António Pestana <afsm.pestana at gmail.com>
Assunto: [FOSS-GPS] Post-processing RINEX to simulate RTK
Para: foss-gps at lists.osgeo.org
Data: Segunda-feira, 24 de Outubro de 2011, 15:56
Sorry if
this is not the right forum to post my question. I’m a newcomer and I am not by
no means a GNSS expert. But I want to learn.
I want to
evaluate the quality of RTK differential phase positioning for some very demanding
engineering applications. Unfortunately I was not able to connect rover and reference station to the same computer, so I could not use commercial GNSS software to do the RTK processing of the observations. As a workaround I decided to store the observations (collected at both sites) in RINEX format files. Now I have a bunch of RINEX files, obs (phase at 20 Hz) and
nav, from base and rover.
I want to simulate real-time (as if they were
obtained in the field) double-differences double-frequencies phase
positioning of the rover by processing these RINEX files. I also need one position
for each epoch of observations and, for now, I do not want to use any kind of “smoothing
filter”. Can I use a post-processing application to do the job ? If this is not
possible, can you explain me why?
Regards
Antonio
PS: Some days ago I’ve found RTKLIB. It’s a very
interesting application. It would be nice if I could use it to solve my
problem.
-----Anexo incorporado-----
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20111024/d62709ff/attachment.html
More information about the FOSS-GPS
