[FOSS-GPS] Re: RTKLIB SKYTRAQ
Grant Oswald
gkoswald at gmail.com
Wed Jan 25 05:53:25 EST 2012
Hello Julio and Volfeer,
Sorry for taking so long to reply.
I'm using the same gps as volfeer. Thats skytraq S1315F-RAW receiver. Only
available from 2 place's that I know. Skytraq sell an evaluation unit for
only $99 usd. Google their website.
My government base station is more than 15 km's away and also my account
hasn't enabled rinex data. (what ever that is). How ever I do have a
government static survey marker at the end of my property. I have searched
the internet and found it's details. What would be the best approach to use
this as reference point? Do I put the gps antenna on this point and collect
data for 1 hour? What then?
Volfeer, based on your picture it seems you have a fix. So you are getting
very accurate data. Well done. May I ask what your settings are? how far
are you from the base station?
Thankyou for responding.
Grant
On Sun, Jan 22, 2012 at 9:35 AM, julio menezes <yjmenezes at yahoo.com.br>wrote:
> --- Em *sex, 20/1/12, Grant Oswald <gkoswald at gmail.com>* escreveu:
> De: Grant Oswald <gkoswald at gmail.com>
> Assunto: Re: [FOSS-GPS] Re: RTKLIB SKYTRAQposition is wondering around.
> Certainly down to sub 10cm. Also are you seeing the base stations sat.
> signal displays in rtknavi?
> I'd really like to use my own base station but I'm not having much luck
> with that.
> Hi Grant
> As you have access to CORS network, and if you have a near station, ( less
> than 15 Km ), you could perform two static ( 1 hour) data collect. Your
> future base station and a rover check point. You have to get the RINEX
> data from CORS and the position of the CORS reference station. Other
> solution should be to perform a static from an known oficial landmark.
> For sure it is possible to process with RTKLIB. I :-( have stoped for a
> while because I have just one receiver, a nice LEA-4T. I have reached very
> precise (static) results with it.
> I bought an Skytrack Venus648FLP but I have to built all the eletronics
> to set it up and seee if it has RAW data capabilities.
> With Skytrack chipset are you working with ?
> best regards,
> julio menezes
> PS: If you have problems to process the static data I can do it for you.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120125/98a41466/attachment.html
More information about the FOSS-GPS
