[FOSS-GPS] Re: RTKLIB SKYTRAQ
Grant Oswald
gkoswald at gmail.com
Wed Jan 25 07:43:11 EST 2012
Hi Julian,
thanks for the quick reply!
The links you mentioned are no good as I live in Australia.
Whats the best settings in rtknavi to collect data? I assume I just set the
output of rtknavi to file? On the rover should I enable corrections from
the cors network as I do this? Or just use single mode?
cheers
Grant
On Wed, Jan 25, 2012 at 11:16 PM, julio menezes <yjmenezes at yahoo.com.br>wrote:
> --- Em *qua, 25/1/12, Grant Oswald <gkoswald at gmail.com>* escreveu:
> De: Grant Oswald <gkoswald at gmail.com>
> Assunto: Re: [FOSS-GPS] Re: RTKLIB SKYTRAQ
> Para: "Open Source GPS-related discussion and support" <
> foss-gps at lists.osgeo.org>
> Data: Quarta-feira, 25 de Janeiro de 2012, 8:53
> Hello Julio and Volfeer,
> Sorry for taking so long to reply.
> I'm using the same gps as volfeer. Thats skytraq S1315F-RAW receiver.
> Only available from 2 place's that I know. Skytraq sell an evaluation unit
> for only $99 usd. Google their website.
> My government base station is more than 15 km's away and also my account
> hasn't enabled rinex data. (what ever that is). How ever I do have a
> government static survey marker at the end of my property. I have searched
> the internet and found it's details. What would be the best approach to use
> this as reference point? Do I put the gps antenna on this point and collect
> data for 1 hour? What then?
> Hi Grant.
> Tks, about your systrack information.
> It is quit hard to by a receicer here. Here our importation tax reach 300
> %, can you beleave that ?
> As you have a landmark, you should:
> 1) Let your base station, where you plan, colecting data.
> 2) Put your rover over the Landmark.
> 3) collect static data by about 1 hour, counting after turn on the second
> receiver.
> the epoch rate can be 5 seconds.
> Any way, I think you can get CORS data from:
> http://www.ngs.noaa.gov/CORS/
> Once identified your near station, download the RINEX data from:
> ftp://www.ngs.noaa.gov/cors/rinex/2012/
> Select the julian day.
> good luck.
> julio menezes
> I am mounting my skytrack Venus638FLPx using an open hardware Arduino Uno
> with a flash shield, I bought from sparkfun. I don't know if it has RAW
> data, I hope so.
> I bought, also an wire less Xbee 60W serie 1, it has 2Km range.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120125/426c4709/attachment.html
More information about the FOSS-GPS
