[FOSS-GPS] Re: RTKLIB SKYTRAQ
julio menezes
yjmenezes at yahoo.com.br
Wed Jan 25 08:38:12 EST 2012
--- Em qua, 25/1/12, Grant Oswald <gkoswald at gmail.com> escreveu:
De: Grant Oswald <gkoswald at gmail.com>
Assunto: Re: [FOSS-GPS] Re: RTKLIB SKYTRAQ
Para: "Open Source GPS-related discussion and support" <foss-gps at lists.osgeo.org>
Data: Quarta-feira, 25 de Janeiro de 2012, 10:43
Hi Julian,thanks for the quick reply!The links you mentioned are no good as I live in Australia.
I see, CORS 2000Km :-(
Whats the best settings in rtknavi to collect data? I assume I just set the output of rtknavi to file? On the rover should I enable corrections from the cors network as I do this? Or just use single mode?
cheers
Grant
Here are my settinx of ulox-LEA4T to colect static data.
Use it as directions. Raplace ubx by skytrack.
Use the same settings for both receivers.
RTKNAVI file configuration:
These are the important settings under GNU/Linux.
Take atention: As I don't have a real windows machine, I have not tested it under windows.
I hope it helps.
regards,
julio menezes
inpstr1-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http) <<< here
inpstr2-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http) <<< here let off
inpstr3-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http) <<< here let off
inpstr1-path =ttyACM0:57600:8:n:1:off <<< here the PC port, may be COMx under Windows,
inpstr2-path =
inpstr3-path =
inpstr1-format =ubx # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
inpstr2-format =ubx # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
inpstr3-format =ubx # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
file-cmdfile1 =../../../data/ubx_raw_1hz.cmd
file-cmdfile2 =../../../data/ubx_raw_1hz.cmd
pos1-posmode =static # (0:single,1:dgps,2:kinematic,3:static,4:movingbase,5:fixed,6:ppp-kine,7:ppp-static)
pos1-frequency =l1 # (1:l1,2:l1+l2,3:l1+l2+l5)
pos1-soltype =forward # (0:forward,1:backward,2:combined)
pos1-elmask =15 # (deg)
pos1-sateph =brdc # (0:brdc,1:precise,2:brdc+sbas,3:brdc+ssrapc,4:brdc+ssrcom)
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120125/cf00aa56/attachment.html
More information about the FOSS-GPS
